Question about Konica Minolta DiMAGE E323 Digital Camera
Dimage E323 "system error"
Camera was working fine. I turned it on, the view finder moved out, but the red light kept flashing....the view finder motor stopped, after a few seconds it groaned for a couple seconds, stopped, then groaned. After a few more seconds, the display showed "SYSTEM ERROR". It's not the batteries, as I had just inserted newly charged (new) batteries. HELP!!!! I love my little camera (although I wouldn't mind more zoom), so I hope it's not toast. Thanks in advance for any help anyone can give me. Pat
  • rachael_rice Dec 25, 2008
    Same deal: new batteries, just stopped working,"SYSTEM ERROR".
    Will only turn on when in menu mode, red light flashes and will not power off. Had to take out batteries to turn it off.
  • 7ciderj Mar 17, 2009
    Thanks Liftboy for # 3. Have tried that and made motor work to its limits again. However, when re-assembled lens came out, jammed again and still shows "system error". What do you suggest next ?
Remove 6 phillipscews open camera.There is a little drivemotor for the lens,next to it is a shaft activating the limit switch for lens opening and closing.Carefully spray plastic safe electronic cleaner into the opening.Now apply 3 volt to the motor reversing polarity a few times to activate the limits. Now use canned air to blow out any residue of the cleaner.This worked for me,camera working again.
Posted on Jan 03, 2009
What size of Memory Card you are using? As far as I know E323 supports only upto 512 MB SD Card. If you are using higher capacity than that, this may be the problem. Try with a low capacity card.
Posted on Jan 07, 2009
I have that problem too with "sistem error"
Posted on Aug 25, 2008
SOURCE:
My son cleared the sd card for my dimage e323 using my laptop after down loading the pics. When I re-inserted the card in the camera it now says it needs to be formated. I have clicked "yes" and...
Formatting it in the camera is the only way to get it to work. Try it again and be sure the slide switch on the side of the card is in the unlocked position.
Nov 26, 2010 | Konica Minolta DiMAGE E323 Digital Camera
New memory card will not work but my olds ones do.
Instead of clicking yes at the first prompt, go into the menu and find "format" and follow the instructions from there.
May 20, 2010 | Konica Minolta DiMAGE E323 Digital Camera
Flashing yellow light beside veiwfinder.
You error message is your flash circuit which need to be replaced they run around 30 plus dollars for the part or it could be the main board just depends. With out diagnosis it it is hard to really tell.
Jul 23, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Konica minolta dimange x50 problem..
Please advise, my dimage x50 wont focus clearly pictures are blurred is there a way to correct this?
Apr 02, 2008 | Konica Minolta DiMAGE X50 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
MINOLTA DIGITAL CAMERA-DIMAGE E323
The battery cover is a different issue. But the wavy lines in your photos sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Oct 16, 2007 | Konica Minolta DiMAGE E323 Digital Camera
OS are supported for USB
The DiMAGE E323 is compatible with Windows98/98SE/Me/2000 Professional/ XP(Home/Professional), MacOS 9.0-9.2.2/MacOS X (v10.1.3-10.1.5, v10.2.1-10.2.6).
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
What AE system does the DiMAGE E323 employ?
The DiMAGE E323 employs multi-segments (256-segments) metering.
DiMAGE E323 dimensions and weight
Dimensions: 99(W) x 62(H) x 34.5(D) mm / 3.9(W)x2.44(H)x1,36(D) inch. Weighs: Approximately 145g, excluding battery and storage media.
Konica Minolta DiMAGE E323 Digital Camera Logo
442 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
