Question about Wytron Technology Wytron-688 DVD Duplicator Controller (1 to 10) Motherboard
Cannot get the duplicator to get beyond COPY< - to GO stage
Turns on fine - then freezes on COPY< - not get any further. working fine yesterday...
Garmin troubleshooting
plug it in to a pc,
hold the flag sybol on your keyboard and press the letter R
type in cmd then ok
typ in chkdsk <drive letter>: /f
where <drive letter> is the letter of the unit e drive g drive etc
if it says this disk is RAW, you have a bad device, otherwise try updating it or doing a master reset
Jul 26, 2014 | Garmin USA DEZL560LT Dezl 560lt gps
Cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
Sony de-435 protect on front
Protect means a problem has been detected in the audio output stage of the amplifier and safety circuits has disabled power from the output stage to prevent further damage. Check the back of the receiver for speaker wire shorts incuding fine threads of wire. The final issue is a short in the audio output stage in the amp that will need a tech to take it to the next level.
Jul 08, 2012 | Audio Players & Recorders
My Fender Deville has suddenly lost power (this is the 60 watt 2x12 model from around 1998) . It still has some volume, but much less than the last time I played it. It has had a history of some minor...
You will need to isolate the fault to a particular stage.
The two large valves are the power output valves and operate in push/pull mode. The next stage is the phase splitter and driver stage. The next stage is the tone control and compensation. The first stage is the pre amplifier stage. To eliminate the output and drive stage you will need to inject a signal at the top end of the master volume control. Touching this point wth a screw driver will inject enough hum to give a strong buzz from the speaker, if this is the case then fault is in pre amp of tone circuity if not. Check screen feed resistors for open circuit (wire wound resistors to screen pins of output valves). Check resistors to anode and cathode pins of phase splitter for increase in value. If the output stage seems ok then isolate the fault further by touching the screw drive to the grid of the valve in the tone network and then the pre amp valve. The buzz will get louder as you progress if the stage is working ok. If not check anode voltages and resistors.
WARNING. dangerous high voltages exist in the circuits. Only ever use one hand when making contact tests, keep the other one in your pocket. If you feel this help is beyond you then please seek professional help.
All the very best from Vintie
Jul 18, 2011 | Fender Audio Players & Recorders
My hp 519j XP freezes when I reboot or if it sits on for awhile -- screen shows on the bottom: &lt;Esc+Boot Menu&gt; &lt;F1=Setup&gt; &lt;F10=System Recovery&gt; but those 3...
press del and get into bios click optimizes settings then save and exit if still the screen doesn't go further remove the power from the hdd and the ide cable or sata cable and remove all the add on cards and restart the system when you restart you find no boot device connect the ide to the primary ide connector and restart your computer if the page doesn't show no boot device change your ide cable
Dec 15, 2010 | HP Pavilion Desktop, 3.06GHz Intel Pentium...
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation
> Blocked VLK
> Windows Product Key: *****-*****-3R89F-D2KXW-VPK3J
> Windows License Type: Volume
> Windows OS version: 5.1.2600.2.00010100.3.0.
Where did you obtain the CD-ROM that you used to install Windows,
using that Product Key?
A "VLK' is a "volume license key" -- when some organization purchases a specific number
of licenses to install Windows XP, Microsoft issues a "volume" license-key,
so that all (up to the number of licenses they purchased) computers in that organization
can use the _same_ license-key.
If Microsoft detects that the product-key is being used *OUTSIDE* of that specific organization,
then Microsoft will *BLOCK* all attempts to "activate" Windows that cite that product-key.
I did a Google-search for '3R89F-D2KXW-VPK3J' and Google reported 37 THOUSAND web-pages that contain that string. That is a *DEFINITE* sign that the VLK has been "leaked" onto the Internet.
So, you are trying to use a "non-genuine" copy of Microsoft Windows XP.
Thus, you are a "SOFTWARE PIRATE".
Purchase a *GENUINE* copy of Windows XP (or Vista or 7) and install it,
and throw away your "pirated" copy of Windows.
Dec 10, 2010 | Computers & Internet
Duplicated print on page
The cleaner of the image drum is not working.
This can consist of ekectrostatic discharge wires OR more likely ios INCOMPLETE transfer of toner due to defect in the charge wires that cause the toner to transfer from the drum to the paper.
Inspect the wires for contamination and use a Qtip to CAREFULLY clean both the very fine wire and the metal channel it is in. Checking the voltage on this wire is beyond what the DIY person can do.
Jul 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
When i turn on the game it work until the first video come the game freezes and my psp shutdown i don't know wher's the problem it's on my psp or in the game pleeeeeeeeeeeeez help???? ps:i have 3.90 m33-2...
It happened to me before. What I did was I downloaded another copy of the game and ran smoothly. The ISO copy you have might be the reason and might be a bad copy.
Jun 22, 2010 | Sony God of War: Chains of Olympus for PSP
What does system error E000 mean for Canon ImageclassD861 copier?
Remove the back plate go to Main Board then go to JP1 remove the Black jumper, connect the power cord, will show message error data and press Green Button (the Big Green for actv the copy) after that the machine do a reset and will clear the error. Return the back plate and connect power again and will work back fine.
TO RESET THE COPIER (after getting an Error Code of E000):
(Canon ImageCLASS D861)
1) Press the Additional Functions button
a. It will blink green
2) Press the < # > button
a. You will see the following:
SERVICE MODE
# 1 SSSW
3) Press the < + > or < ►> button until you see the following:
SERVICE MODE
# 7 PRINTER
4) Press the < Set > button
# 7 PRINTER
# 1 SSSW
5) Press the < + > or < ►> button until you see the following:
# 7 PRINTER
# 4 PRINTER RESET
6) Pres the < Set > button
# 7 PRINTER
< YES NO >
7) Press the < – > or < ◄ > button to choose YES:
# 7 PRINTER
# 5 MLT CLEANING
8) Unplug the printer and wait for 15 seconds. Then plug it back in.
Feb 18, 2010 | Canon ImageClass D861 Printer
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
Wytron Technology Wytron-688 DVD Duplicator Controller (1 to 10) Motherboard Logo
24 people viewed this question
Top Wytron Technology Computers & Internet Experts
David Payne
David Payne
Are you a Wytron Technology Computer and Internet Expert? Answer questions, earn points and help others
