Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hi my printer doesn't pull paper from tray1 even if it set to pull paper automatically from tray 1 and 2 inadditon to this it needs manuallly feed papers.
  • Anthony Lam May 11, 2010
    Is printer asking for different type of paper ie you loaded letter and its looking for A4? what is the model and brand of the printer? does printer pull fine from tray 2? Is tray 1 your multipurpose tray?
My HP OfficeJet 7310 behaved correctly on the automatice paper feed for a long time and then began to be unable to pick up the page or would grab 2 or 3 pages at once. I was about to spend the $$$ to replace it, maybe $400 at that time. Instead I watched it work again and angin or not work. Noice the 1 inch square piece of cork? I went to Hobby Lobby and for less than $2 bought a roll of very thin cork. I cut an inch square and replaced the one on the machine and it has worked perfectly since. I still have 99% of the cork roll. What it?
Posted on Apr 18, 2009
  • EducateLad Jul 01, 2011
    How did you get at the 1 inch square piece of cork? Did you have to take anything apart?
  • danielpifko
    danielpifko Apr 15, 2012
    That worked really well. I left the existing piece of cork in place, cut a new piece of cork about the same size, beveled the edge of the cork toward the stack of paper, and just held it in place with a bit of clear tape overlapping the bevel. It works really well. I'll probably put in a bit of double-sided tape under the cork too.
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed tray bypass
Jul 25, 2012 | HP LaserJet 4250n Printer
Paper is jamming as soon as the paper gets in halfway through tray 1. its a pamphlet sized paper and i have changed the seeting on the printer. tray 2 works perfectly but since the paper i need to print on...
Sarinana
Hi
The problem is with the size you are about to print. Try to use the paper in landscape then Portrait as this may solve the problem. As the paper sensor in the printer is in the middle of the feed assy. and sometimes it may not detect the paper correctly. And also try to use the size as A4 but make the changes in your software you are printing from.
Hope this will solve the problem.
DO RATE MY SOLUTION
Regards
Jun 29, 2011 | HP LaserJet 2420 Printer
My Hp Laserjet P3005D doesn't feed in tray 1. But when i do an Engine Test . It work and feed the paper ang make an engine test printout. What do you think is the problem. Action taken : Replace DC...
Are you selected manual path while shooting the data?Check tray 1 paper sensorIn printer menu settings select as always from tray1.. try it I hope it will solve the issue.
Feb 09, 2011 | HP LaserJet P3005n Printer
How do I select paper tray 2
You can set the Brother machine to automatically select the appropriate paper tray based on the paper size or you can manually select paper tray1 or 2. If you use the Auto Select feature, the application will automatically pull from the appropriate tray based on the document#s paper size. For this feature to work, the tray settings must be definedfrom the machine#s control panel. For instructions on how to configure this setting, continue to the section labeled: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING)
PART 1: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING
1. On the Brother machine, press MENU.
2. Scroll to and press GENERAL SETUP.
3. Scroll to and press TRAY SETTING.
Oct 29, 2010 | Brother MFC 6490CW InkJet Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Jan 30, 2008 | Lexmark T630 Laser Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
201 people viewed this question
Ben Johnson
