Question about Dometic 12V Refrigerator Light Cover
Hi, I just smashed my light cover by accident..is the fridge still safe to use could you tell me plse? Kind regards, Tracy
Its a Beko Glacier. The whole cover is gone exposing the bulb?
Why does beko glacier fridge icebox makes too much ice and freezes interior flap shut??
2 possibilities
moist air getting in by way of damaged door seals or bent door not sealing
or your inside (evaporator fan is not working) do you have lots of frost all over you items in the freezer. if so then check if the door sealing...turn off all lights in your house at night and put a torch in your freezer shut the door and see if there is any light. a little bit will cause you issues
May 24, 2014 | Refrigerators
My beko glacier freezer is not freezing
evap coils could be frozen due to bad defrost timer or heater. could be a bad evap motor or worst case the compressor could be bad
Feb 10, 2012 | Refrigerators
Hi I have received a letter asking to contact if I have Fridge Freezer with potential fire hazard. Eventually found serial number and its one on the list 006 CDA653FW
Hi patburn912,
Unplug the fridge, and call them on 0800 009 4837 - Rather be safe than sorry.
Kind Regards
JEDMEYER1
* If this helped, please rate it
Aug 21, 2011 | Beko Refrigerators
I HAVE A BEKO FRIDGE FREEZER MOD CGA 963 NS SER NO 0510054901 COULD YOU PLEASE TELL ME IF THIS PRODUCT IS SAFE
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006 (So, after shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008)
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
Jul 06, 2011 | Beko Refrigerators
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Assembly Instructions Durham Cot Bed
Have attached a copy of my instructions
Mar 10, 2009 | Baby Gear
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Dometic 12V Refrigerator Light Cover Logo
18 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
