Question about Lincoln Electric Welding Tools
Is the lincoln p20 plasma a pilot arc machine, need information
2 Suggested Answers
  • 9 Answers
SOURCE: plazma cutter/no arc
The Cutmaster 50 used two different CD "Capacitor Discharge" Boards. The only ones I have seen a lot of issues with were the smaller ones that are 3.5" X 4"
I have worked on several of the them over the last few months. Even though you might see a spark at the spark gap on the board it might not be sufficient to create a pilot arc.
If your air pressure and so forth are correct your issue is most likely the two white capacitors on the CD board.
Posted on Nov 07, 2009
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
(From: https://app.aws.org/forum/topic_show.pl?tid=31328)
"Remember, they are a drag machine up to about 3/8" thick material. Keep the power down as low as possible for the material being cut. Keep the right air filters on to supply clean air. Keep the air pressure between 60 (min or it will shut down) and 70 for most applications (more is not better-just like oxygen on the torch or air to an air-arc).
Also, check that the air hose hasn't come loose from the gun.
That was Brian's problem from YouTube (http://www.fixya.com/answer/answerpageslideview.aspx?thid=26182813&ctg=373&brd=5236)
May 02, 2016 | Lincoln Welding Tools
Lincoln electric pro cut 80 want arc
Try replacing it as in remove and than put on again
Nov 25, 2012 | Lincoln Electric - Pro-Cut 80 Amp Plasma...
Pilot arc is highely spreaded
change the cutting nozzle
Mar 23, 2012 | Hobart Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Shuts on on safety ,,almost immediatley
Check that the tip is assembled correctly.If is not in properly, it will not arc. Second, check air pressure switch. Sometimes they become stuck from corrosion due to moisture in the air. Test the operation with a tester
Nov 01, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
If you have a old plasma cutter can you swap ot
yes it does matter.each brand is set up for their own torches.
Jul 02, 2009 | Welding Tools
Welding Tools Logo
27 people viewed this question
Top Lincoln Electric Welding Tools Experts
Troy
Troy
Level 1 Expert
AZBen
AZBen
ka4iup
ka4iup
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
