Question about ModernEuroDesign Bermuda Modern European Click-Clack Mechanism Sofa Bed
Want to make a click clack sofa for a boat - ModernEuroDesign Bermuda Modern European Click-Clack Mechanism Sofa Bed
Click clack stuck
you need a grease that is good for water, usually white. use a tap or spindal grease.
The main problem hear is probably the type of soap that you are using. cheap ones usually have a high content of costic soda and this will remove any lubricant that you put on your click clack.
Dec 21, 2013 | Home
Is there a storage place inside sofa beds?
This is the most annoying issue regarding sofa beds. Most sofa beds designed to save as much room as possible therefore there is no storage area for sheets and pillows inside and if you find a sofa bed with storage place, it would probably be a huge sofa.
Aug 20, 2012 | Furniture
Would it be comfortable to seat on a sofa bed?
Before you buy a sofa bed you have to make sure that it is comfortable to seat on the sofa. Many sofa beds look absolutely gorgeous but when you sit on the sofa in is not as comfortable as it looks.
What is a drop-end sofa-bed?
Drop-end sofa-beds are ideal for smaller spaces such as apartments. By using a lever, you can convert this type of sofa-bed from a sofa, to a chaise lounge, to a small double bed.
Aug 16, 2012 | Furniture
What is a sectional sofa?
A sectional sofa is simply a sofa comprised of several sections. They are perfect for larger households. Here is an image of a sectional sofa -
Aug 14, 2012 | Furniture
Where can I find a fuchsia sectional sofa?
Here it is: http://www.shiparoom.com/ProductDetails.asp?ProductCode=FS03B&click=71&utm_medium=shoppingengine&utm_source=nextag and a really good price too. I, personally would tone down the pillows and have just plain back and white as the sofa's color already attracts so much attention. I just hope that you will not get tired of this too soon.
May 29, 2012 | Furniture
What will cause a Clacking/Clicking noise coming
It maybe a loose heatsheild on the manifold, converter, or underbody heatsheild.
Jun 03, 2010 | 2000 Jeep Grand Cherokee
There is a clacking noise coming from the rear of the boat. It is a Chaparral with a 260hp Alpha drive. It started suddenly and seems to be getting worse each time we drive the boat. Engine runs good and...
With boat on trailer put drive in gear,engine off,remove bellow cover on the lower unit and check u-joint for any slack or noise when you try to rotate prop.Does clacking happen more when you raise lower unit?
Nov 15, 2009 | Boating
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Hard drive wont run
No, their is not. You can try disk cleanup under properties of that hd.
Dec 31, 2008 | Computers & Internet
ModernEuroDesign Bermuda Modern European Click-Clack Mechanism Sofa Bed Logo
37 people viewed this question
Top ModernEuroDesign Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a ModernEuroDesign Furniture Expert? Answer questions, earn points and help others
