Question about Pyle Audio Players & Recorders
Pyle pro pdwm2550 charging question
The manual says nothing about the switch position on the mics whe3n charging, first click or off
Are replacement antennas available? how may we get one (or more)? Thanks
Yes, they are called a BNC antenna. Type that into your search engine and you will find many suppliers online. Very common thing to replace.
Apr 05, 2016 | Pyle pro Pdwm4400 4-mic Vhf Wireless...
Cannot get battery to charge
The battery may be unable to charge and probably will have to be replaced.
Oct 21, 2014 | Pyle Pro PWMA1090UI 800W Dual Channel...
How to install the 9V battery in the PYLE PWMA200?
The 9V battery is for the mic or the transmitter from what I can tell. According to the manual, the bottom of the mic is where the battery compartment is located, and it unscrews. You can get the manual here: http://www.pyleaudio.com/sku/PWMA200/Rechargeable-Portable-PA-System-with-Wireless-LavalierHeadset-MIC-and-1-Wired-Mic
May 30, 2014 | Pyle PWMA200 Rechargeable Portable PA...
Pyle troubleshooting
You've obviously checked battery strength, battery connection and volume settings for the dead mic...does the green transmit (RF) LED light when you turn the mic on? Does the red audio (AF) LED light when you talk into the mic? Best solution....buy a better quality wireless system ($85 wireless?!? ...no thanks).
May 20, 2014 | Pyle PDWM2100 Microphone
How can I get the frequency chart for Pyle wireless mic?
look for the product on pyles website. there is a manual attached to the product discription
Feb 16, 2014 | Pyle Audio Players & Recorders
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
Pyle Pro PDWM 4300
I contacted the manufacturer and they verified that this was possible. I will test prior to the event. Thanks for responding.
Apr 08, 2009 | Pyle PDWM4300 Professional Microphone
Microphone problem
hi i know this is old but would you like to sell it ?
isit a beyerdyamic m560?
May 29, 2008 | Audio Players & Recorders
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
