Question about Sharper Image Itower Si333 Speaker
Itower won't play
Powers up but no sound comes out. I bought a new charger cause we lost the original.
Unsupport this accessory Is what keeps coming up
I have seen this happen as well. Usually it is caused by corrosion on the cable connectors. Clean the connectors with rubbing alchol or electrical cleaner and see if that helps. It may only work for a while as over time the corrosion comes back. It usually happens on cheep aftermarket cables.
Aug 07, 2013 | Apple Soundlogic Itower Speaker Works W/...
My Fujitsu Lifebook AH531 won't start up all all, as if the battery is dead. I've bought a new charger and the problem remains. Can anyone help please.
you need to find out if you are getting voltage to motherboard may be a bad jack if you do not have the tools bring to a repair shop
Jan 19, 2013 | Fujitsu LifeBook AH531
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
Power plug for iTower S1333
I just bought a replacement power supply with the round 4-prong plug for the i333 from lcdpayless on e-Bay.  Contact them and maybe they will sell you the plug only. Link is below:
http://cgi.ebay.com/24V-AC-adapter-for-Sharper-image-iTower-SI333-speaker_W0QQitemZ360150936670QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item53daab2c5e&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A1%7C293%3A1%7C294%3A30
aschaef
Mar 15, 2009 | Nakamichi AV-10 Receiver
Sharper Image Itower Si333 Speaker Logo
Top Sharper Image Home Security Experts
Lawrence Oravetz
Are you a Sharper Image Home Security Expert? Answer questions, earn points and help others
