Question about Weiser Lock Powerbolt 1000 Lock
Center button unlocks insted of locks code locks insted of unlock
I would like an answer on how to fix it so when I press the lock button on the center of the Weiser powerbolt it will lock. Now when I put in the code it locks the door and I want it to unlock the door when I put in the code. How can that be changed?
    Sniper:
  • 68 Answers
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
    Problem Solver:
  • 16 Answers
I have had the this lock for a number of years and it's worked perfectly until I entered a 2 nd pass-code. Now it's doing the reverse locking on the key number entry and unlocking on lock button.
When I take out a battery and let it reprogram itself it work perfectly until the door is closed and then it reverts back to the problem.
any suggestions?
Posted on Oct 24, 2012
  • George Robson Oct 24, 2012
    Just fixed it but I thought I'd give other the solution.. the Jumper connector was loose and not making a good contact thereby letting the locking mechanism change direction at will. I just spread the pins apart and problem solved.
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Aug 18, 2012 | Weiser Lock ED1460X3VKD Powerbolt 1000...
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
Change combination, lost book
Here is a link to the complete instructions:
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
How do I reprogram the entry code for weiser automatic powerbolt lock?
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Aug 02, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
The original code will not clear from my Weiser lock electronic lock. I have entered multiple codes and the original still stays. How do I get the original to clear.
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
May 04, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
It's working in reverse order - I have to put the code in first to lock it, which leaves it ready for someone to break in because all they have to do is press the lock button and it will open. How do I fix...
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
his should help:
https://s3.amazonaws.com/Kwikset/Powerbolt%201000%20-%20Installation%20Instructions.pdf
Kwikset and Weiser are part of the same company now.
If the above link doesn't work, this is from their site:
Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
Locate the small round program button near the left side of the circuit board (Red or Black).
* To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
* To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
Apr 14, 2010 | Weiser Lock Powerbolt 1000 Lock
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
After changing the code, it will not delete the old ones. how do you do that?
Be sure to change both codes. Press "program", then the code, then the lock button. Then press "program" twice, then a second code, then the lock button.
Nov 30, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock Powerbolt 1000 Lock Logo
723 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
