Question about Sens S1901DVD 19 LCD TVDVD Combo
I have a sens 1901DVD it selects when it wants to be full screen on channels and commercials. I ask direct tv but they say its the tv not their service. Is their some way I can just make it full scree
How do I set full screen on my sens S1901 DVD tv so it stays all the time, every channel and all comercals?
My sony str dh710 broadcasts sound from tv shows andsome commercials. But sone commercials have no sound. Why?
if your saying that overall the sound works just fine but just some commercials don't have sound , this surely is a cause that not all commercials have Dolby decodable sound , this receiver has a dolby decoder inside it , im betting that you use the dolby sound selection most often , a simple test of theory is to select 2 channel stereo sound in set up and watch same commercials if you got sound now there's your problem , I do ask that you not complain to broadcasters of this (they might fix this) as id rather enjoy missing the entire commercial but no sound would be a viable alternative
Oct 21, 2015 | Sony Audio Players & Recorders
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
I can't get the full screen on some hd channels and during commercials. It goes from full screen viewing on some channels to the picture shrinking and having a border around it.
There are a few picture sizes out there 4:3, 16:9, as well as some for movie screens. New televisions are 16:9 and when you are watching a true HD program, it will fill the screen perfectly. However the program may be broadcast in one of the other formats. This results in the bars on top/ bottom or on the sides. This is true for commercials too. If the commercial is or isn't in HD will determine if there are bars or not. All this is normal operation.
Apr 20, 2011 | Televison & Video
Sony Bravia KDL-52XBR6 screen adjustment
That sounds very normal to me. When your watching a HD channel, and a commercial comes on and the screen gets smaller with as you say the black bars, just means that the commercial is not broadcasting in HD. You can change it by pushing the button on your TV remote that says picture, but you are streaching the screen and are going to loose the quality of the picture. You may also want to spend a few hours, going into you TV settings and just start playing with the settings. Just remember where they were before you change something. You can also purchase a guide to LCD settings to point you in the right direction. If you have your TV set to vivid or one of the preset picure modes, it is costing you more power and you are not getting the best picture that the TV can produce. Play around with the custom setting or buy one of those calibration CD's off the internet.
Nov 09, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
I have GE XS Stereo Commercial Skip Model 27GT619
  1. On the front of the TV press the MENU button to display the MAIN MENU.
  2. Scroll through the choices using the VOLUME up and down buttons
  3. When positioned on the selection you want press the MENU button again.
  4. The first SETUP screen displays, asking you to select a language.
  5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
  6. A SETUP screen appears asking if you would like the TV to search for all channel
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
  8. Complete the SETUP routine or skip any of the steps and return to them later.
This information is from the User Guide that came with our set. Good Luck.
Jun 11, 2009 | GE 27GT271 TV
My television screen size keeps changing when on satelite channels, why is this?
Hi, You have selected "native" in the video menu which means it will switch to exactly the format being broadcast, like a full screen on a movie and then four inch bars on the sides for a commercial. Change your video setup to display a format other than native. It will still switch if your satellite box has these options as well, so check both. Good Luck, hope this Fixsya!
Feb 23, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Commercial Skip Feature
When a commercial comes on, you press the "Commercial Skip" button on the remote. Then you see a 30-second countdown timer appear on the screen. If you think there will be more than 30-seconds of commercials, then press the button more (each time you press adds 30 seconds to the on-screen timer -- usually I press it 4 to 5 times). The timer stays counting down on the screen while you change channels during the commercials to see what else is on. When the timer counts down to 0, it is erased from the TV screen and the TV automatically changes you back to the channel it was on when you pressed the commercial skip button. I use this feature a lot! I wish all TV's had it built in. Some universal remotes have a similar (but more awkward feature) where the remote has the timer inside it, and it sends a signal back to the TV when the count is up, but I don't think this would work as well.
Oct 21, 2007 | GE 35GT740 35" TV
Sens S1901DVD 19 LCD TVDVD Combo Logo
23 people viewed this question
Top Sens Televison & Video Experts
Are you a Sens Televison and Video Expert? Answer questions, earn points and help others
