Hi. Love my projector. For some reason tonight, it wouldn't sync with my laptop for an important presentation. The cable works, because we used my cable (pin connector) to hook up the other projector. everything worked fine. The light comes on.. it just says...no signal...Any suggestions?
  • kllyhoward Jan 26, 2009
    Yes. Ive pressed the FN Key while holding down the F7 key which has the symbols you talked about. It will flash for just a moment like it is going to read it, but then it doesn't. Is there a place where I can choose Screed Displays somewhere else? By the way. I worked on it til 2 that morning...never got it working. Unplugged everything and it worked the next day without doing anything at all. Then tonight when i was going to use it again, it did the same thing. UGHGHG!
  • 79 Answers
Have you toggled the output display function key on your laptop. Should look like a Square Screen and Laptop symbol. Plug in the projector and keep pressing this button.
Posted on Jan 25, 2009
My hp m3222 projector is not working with my laptop via USB cable
The USB connection only allows the projector's remote control to be used as a "mouse" to advance presentation slides on the PC and perform some other limited functions. The USB connection cannot be used to feed video or other signals to the projector. Refer to the operation manual here:
HP mp3220 series User Manual
Feb 26, 2015 | HP Hewlett Packard MP-3222 Compatible...
Connect laptop cable
Hi Anna,
It is impossible to connect to a projector with just a usb cable. You will need a VGA cable (for older models of projectors and laptops) or an HDMI cable which can be used with newer models.
Best of luck to you.
Jan 26, 2014 | Hitachi CP-X260 LCD Projector
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
I can't project my image from my laptop to the projector..
A usb cable will not work that way--on your projector, it's used for data...you need to obtain a monitor cable which will plug into the vga connector on the laptop and into the connector on the projector (rgb in 1) or (rgb in 2) If you use the #2 rgb input, make sure the button IS NOT pushed in! If it is, the projector will be switched to OUTPUT mode on the #2 connector. Also, on the laptop, normal operation is "laptop only"...when you push the <alt F4> buttons, it should then switch to "laptop + external display(projector)", another <alt F4> push will give "external display only" mode. Then, another push will return you back to "laptop only". NOTE: Sometimes, you have to turn on the projector first, then immediately turn on the laptop--not to get technical but different equipment can get finicky about syncing up...just something to be aware of...
Aug 31, 2009 | Hitachi CP-X250 Multimedia Projector
Need to connect my dell laptop to a large screen projector using a computer video interface for vga and compatible computers I have a delllatitude d610 the interface is an inline2080
I assume you know how to connect the VGA cable and which function key is used to activate the second display. You will have problems if the laptop display size is not supported by the projector. Many older projectors will not work with wide screen laptops.
when you connect the projector, Just press the presentation mode on your keyboard, Fn + (Presentation Key), Sometimes F5 or F8!
Then you will see your desktop on the projector screen.hope this helps
Aug 13, 2009 | Dell Computers & Internet
Laptop is not being connected
THE PIN CONNECTION MAYBE DIFFERENT IN THE OTHER LABTOPS YOU WOULD HAVE CONTACT THE VENDEER AND CHECK THE PIN OUT FOR THAT PORT AND SEE IF THEY ARE THE SAME.
THE COMPUTER CABLE SPACIST CAN HELP YOU, CABLE CONNECTION, CABLE AMERICA, AND CABLES TO GO.
ROD
Feb 17, 2009 | Sanyo PLC-XU73 Multimedia Projector
Presentation mode is off...
Hi there
You cannot hook up a PC & Projector with just a USB cable , you have to use a VGA cable for signal ( picture )
The USB cable is just to use the scroll up or down function from the standard remote controll when doing a presentation.
Apr 14, 2008 | Hitachi CP-X260W Multimedia Projector
Sanyo pro xtrax projector
listen im a comp wiz on the remote press video 1 egt. if that doesn't work trash it
Sep 20, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 10, 2007 | NEC MultiSync GT1150 Multimedia Projector
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
