Dec 30, 2014 | Sony Handycam HDR-HC7 Mini DV Digital...
Nov 24, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jul 31, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
May 02, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
The lens cover mechanism in these cameras is susceptible to debris and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Feb 01, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
Dec 22, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Oct 01, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
May 19, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
Sep 17, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
47 people viewed this question
power cable is ok Fuse in unit has been checked fine but the SA-HA7 will not operate is there a reset button inside the unit as it has an 80gig hard drive
mine is the same did you find a fix pls?
