Question about Kirby Vacuums
Switch on Kirby G3 does not work
When I push on the on/off switch I sometimes see electricity momentarily get to the light. However, power to the vacuum does not fully engage. Does any one know where I can download a repair manual for free or can someone tell me, step by step please, how to repair the switch. Thanks a bunch.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 88 Answers
To tricky to self repair, you have to strip the motor down to replace speed switch, contact your local kirby service centre
Posted on Jan 28, 2013
reddevil6
  • 1673 Answers
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Posted on Jun 21, 2008
b0sslady2001
  • 357 Answers
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Posted on Oct 25, 2007
SOURCE: Vacuum Power Switch on Handle Doesn't Work
The switch is very cheap. I have the same vacuum. The solution is to stick a thin peice of cardboard under the slide track for the rod in the handle assembly. You will see the rod when you disassemble the handle for the sweeper. Move the on/off switch on the handle assembly a few times and look at the bottom of the of the assembly to see a thin black rod with cut grooves. This rod activates the on/off switch.
There is a little track that this thin rod of plastic travels along. However over time the the plastic rod begins to recess further into this track. The rod still slides but is now to far away to activate the on/off switch. This isn't very technical but just slide a thin peice of hard paper or cardboard between the rod and the slide track.
Make sure the red on/off switch on the sweeper is set to off. Put the handle back with the switch in the off position. Test the sweeper using the handle a few times before reassembling the screws. This fix may not be permanent according to how you have the paper/cardboard set between the slide track and the rod but it works very nicely.
Hope this helps! : )
Posted on Jun 23, 2008
b0sslady2001
  • 357 Answers
SOURCE: The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Posted on Aug 07, 2009
  • 231 Answers
SOURCE: Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
Posted on Jan 03, 2010
How do i fix the on and off switch on a kirby g3
see the video attached use the common sense: God bless you
Jul 31, 2012 | Kirby Vacuums
How to tell which part of kirby g3 electric motor is bad
normally its the field wire that goes first, needs visual inspection,
cant test power switch,so will have to test with new one
Jun 02, 2012 | Kirby Generation 3 Bagged Upright Vacuum
Our G3 Kirby will not power up?
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
Apr 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My vacum is not powering up
Reason number 1 (not sure why Kirby Co. still has not fixed it) - improperly installed outer bag. You have to push the bag all the way to the unit so it presses the safety switch that is between exhaust and the vacuum shell
Reason 2 - defective cord - try wiggling it. If you know how to do it - try removing cord and supplying power directly to the unit using another cord or wire (ONLY if you know how to work with electricity.If you get zapped - do not blame me)
Reason 3 - bad power switch (instructions on how to replace it HERE)
Reason 4 (very unlikely) - motor KAPUT
Apr 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hi! I'm interested in purchasing a G3 model ; however , the seller says that the machine was working perfectly and then when switching power on a while later , the machine was " dead " . Other...
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums, I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Kirby Vacuums
Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
My G3 works with the hose, but not with the Tech Drive
Try removing the nozzle and poking a screwdriver in the little slot for the safety switch and seeing if it runs. Maybe the nozzle's poker isn't pushing it in adequately?
Apr 30, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
87 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
