Put shifter in any forward gear posistion and it seems to stay in 3rd gear. does not happen all the time.
SOURCE: BMW 318 Automatic - Gears
something may be loose or soo old it may need replacing if worn from miss use or hard work or pressure for your own safety
SOURCE: Automatic Gear shift stunk in park
your gear shift stunk in park!???? what does it stink like???
SOURCE: My 2004 bmw x5 jerks when first putting the
hi , you may need to get the gear box oil level checked as this seams that it may be a little low , you could also tryrunning the engine for a minute or so , this would allow the oil to warm up and hopefully engage the first gear correctly , regards mark
SOURCE: 1988 bmw 325is power windows quit working but
If its both check the fuse yes it could be a relay.
Testimonial: "5stars"
SOURCE: 1996 bmw 328i automatic seems
Hi! Your car might went to limp-home-mode to prevent further damage. Check the valves for it might be sticking on the transmission valve body assembly. Its just gonna be it, nothing else. Hope this helps and have a good one!
