Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
My brand new toilet american standard round front model cadet 3 tank not fill water
American Standard Cadet 3 Right Height round Toilet by - ADA Compliant
  • Rose chu Jan 12, 2013
    Thank you very much. I changed new pipe, new valve ,debris blocked inside the old one. The toilet is working perfect now.
    Top Expert:
  • American Sta... Master
  • 34,153 Answers
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Posted on Jan 11, 2013
3 Suggested Answers
  • 83 Answers
SOURCE: i recently bought (9
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Posted on Nov 21, 2010
shepnaz400ex
  • 46 Answers
SOURCE: How much draw down (tightening) do use to attach
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Posted on Sep 04, 2009
Relace flush valve seal
The American Standard Cadet 3 flowise one piece toilet uses a flapper valve with a soft nylon washer to seal against the water outlet.
Over time this nylon washer develops 'puckers' causing water to seep between the nylon washer and the seat of the flapper. This seepage causes the water level in the tank to drop to a point where the water inlet valve opens to replace the lost water in the tank.
There are two ways to correct this problem:
1. Replace the soft nylon washer on the flapper, or
2. Replace the entire flapper valve.
Hope this solution helps.
Apr 15, 2014 | American Standard Cadet 3 Right Height...
My toilet keeps filling on it's own
Replace flapper. Use American Standard flapper for your unit.
Sep 11, 2013 | American Standard Cadet 3 Right Height...
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Feb 22, 2011 | American Standard Cadet 3 Right Height...
How much water should be in tank when installing a American Standard toilet-
There is a water line cast on or into the side of the tank. They are generally set from by the type of filler system you install. Thats a different matter.
Feb 20, 2011 | American Standard Cadet 3 Right Height...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
Nov 21, 2010 | American Standard Cadet 3 Right Height...
Toilet water valve does not fill water in the tank
Went to Lows and got a new fluid master water valve. Before I got any advice it's done.
Jan 13, 2010 | American Standard Cadet 3 Right Height...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
Sep 04, 2009 | American Standard Cadet 3 Right Height...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
320 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
