Question about Fargo DTC525 ID Card Printer
Fargo Printer DTC525 Said Card jam, I can't found any card jam follow the instrucctions to remove a card jam. What can I do?
  • 6 Answers
SOURCE: Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Posted on Jun 27, 2007
SOURCE: Fargo c16 card printer
Try cleaning all the rollers.
Posted on Apr 16, 2008
  • 81 Answers
SOURCE: Problem on card print using Fargo DTC525 Single Side Print model
I think the problem is in the printer definition. Perhaps the software is calling for the output to be duplexed. The printer does not have a duplex installed so it creates the error. On the other hand, if the printer does have the duplex option, then you are looking at a printer problem.
Posted on Jun 11, 2008
SOURCE: Card Flip Jam Error message
Open the left hand top cover, In between the ribbon rollers you will see a small flipper, ( small piece of metal with a wheel stuck on one end. ) Maually turn this so the grey wheel is on top and white smaller wheel on the bottom.
This ocassional gets jammed and need righting manually.
Posted on Aug 14, 2008
  • 526 Answers
SOURCE: Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
Posted on May 31, 2009
Which tipe of ribbon to be used in DTC525
hello
http://www.idsuperstore.com/fargo-printer-ribbons-fargo-dtc525lc-ribbons-c-5_79_1472.html
try this link for your ribbon printers
thanks
Mar 03, 2011 | Fargo DTC525 ID Card Printer
Printer is printer light and havin color problems
You can either change the image darkness level on the printer or through the printer drivers.
on the 525 control panel, you can go to the setup menu, and search through it until you see image darkness, select it, and change the values, go up or down by 10 points at a time.
in the printer drivers, go to printing preferences, and there is a tab that
will have image darkness in it.
Jan 21, 2009 | Fargo DTC525 ID Card Printer
520 vista print drivers
They dont make vista drivers for the 520.
Jan 13, 2009 | Fargo DTC525 ID Card Printer
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Resolving a Card not fed error (Cards will not feed off the Hopper)
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Printer restarts itself after putting it on
We would recommend to try to update the firmware for this printer from the Fargo website - www.fargo.com. Update the print driver to the most current version from this site as well. Run a test card from the LCD panel if the printer starts after your updates. If successful, run a test card from the print driver on the computer.
If this does not work, there may be major issues. Contact Fargo Technical Support at 800-459-5636.
Visit our id card printer blog for additional Fargo information at www.safecardid.com/blog.
Oct 14, 2008 | Fargo DTC525 ID Card Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
Is there a fargo certified service center in the Seattle or surrounding areas?
You could look at Fargo website www.fargo.com to find service center neer you or call customer service they will help you Number on website
Aug 06, 2008 | Fargo DTC525 ID Card Printer
you can check with fargo, or perhaps your vendor is giving you the bad rep, since they refuse to help you. i would not do business with them again.
if the printer worked before maybe the program needs to be reinstalled.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 10, 2008 | Fargo DTC525 ID Card Printer
Fargo DTC525 ID Card Printer Logo
89 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
