Question about Video Game Consoles & Games
Connection error on smartnav
I have wired smartnav in Red -12v black earth and blue - ignition. I am getting connection error? There is a brown and purple wire spare?
  • 98 Answers
SOURCE: Trying to fit G202 electronic
The colour coded wires seem to differ at randomn. To identify the cables:
Dizzy:- use a multimeter set on ohms.. When you measure about 3 meg ohms, your red probe is on the +ve wire and the black probe is the signal to the coil.
For the coil, it hard to measure the primary resistance so the general convemtion is looking at the pins on the coil with the taper at the top, the +ve is on the right and the signal (coil -ve) is on the left. Sometimes you'll notice one of the wires on the coil is a thicker gauge, which is generally the +ve.
Posted on Sep 09, 2008
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
SOURCE: do you know where can i get the red n black thin
I know the wires you're talking about.
You can look around and see if a friend or whatever has a broken PS3, then you can snag the wires off of those. That might take a while, as the models of the PS3 differ.
If you have no luck, you can take it into a specialist and they can repair the connection.
It would be cheaper than sending it to Sony.
Plus you voided the warranty by opening it up in the first place.
I'd say don't touch anything else. Unhooking more wires could make your Blu-Ray inoperable. Even if you connect everything back real snug.
Posted on Jul 17, 2009
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I need a fuse diagram for 2001 Nissan Pathfinder
Do you want to install a new unit or wht ? u may use this reference to work upon ....
Get yourself a digital multimeter. Find the +12V constant, 12V remote, and ground. Connect them to the new head unit. For speaker wire get yourself a 9V toy battery and listen to poping noise. If you have a factory amp you need to power up the factory amp. Use the wiring diagram below to serve as a guide. Test your wire first before connecting them.
NISSAN
P o w e r
Memory (+12v Constant) Red
Ignition (+12v Switched) (varies) Brown or Green
Ground (-) Black (varies - most don't have one)
Illumination Red/White
Dimmer Red/Black
Power Antenna Green
S p e a k e r s
Right Front (+) Brown
Right Front (-) Brown/White
Left Front (+) Black
Left Front (-) Black/White
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
Feb 04, 2010 | 2001 Nissan Pathfinder
Need to install my clarion vrx755vd, but have no wiring diagram
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
orange/white illumination
brown phone interrupt
grass green connect to earth if u want to watch dvd's whilst you drive
rate pls
Nov 17, 2009 | Clarion VRX755VD Car DVD Player
Need stereo wire diagram for 1993 honda civic
Memory (+12v Constant) Blue/White Ignition (+12v Switched) Yellow/Red Ground (-) Black Illumination Red/Black Dimmer (none) Power Antenna Yellow/White S p e a k e r s Right Front (+) Red/Green Right Front (-) Brown/Black Left Front (+) Blue/Green Left Front (-) Gray/Black Right Rear (+) Red/Yellow Right Rear (-) Brown/White Left Rear (+) Blue/Yellow Left Rear (-) Gray/White
Oct 20, 2009 | 1993 Honda Civic 4 Door
I have a 2000 accent.I'm trying to self install my old eclipse deck but need a diagram for the accent wire set up.
Black - Neg. (-) earth, Orange/Black stripe - Constant 12V, Blue/Black stripe - ACC 12V, Green/Orange stripe - Pos.(+) Dimmer, Green/Black stripe - Neg. (-) Dimmer.
There are two Orange and two Blue wires, you will need to work out which is which, it's not hard.
Front Right - (+) Brown,(-) White;
Front Left - (+) Red, (-) Blue;
Rear Right - (+) Blue, (-) Orange;
Rear Left - (+) Green, (-) Orange.
Sep 01, 2009 | 2000 Hyundai Accent
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
I wanna connect my amp, and i dont know which is the remote wire? where do i connect the blue wire to? i have a sony cdx-f7700. can anyone help or have a diagram
The blue wire, if you've not got a corresponding blue wire to connect to can be connected to the ignition wire. That being one of three needed to power your head unit - RED (12v permanent), BLACK (negative / earth) and another colour, sometimes blue for 12v ignition (only comes on with the ignition on / acc).
Aug 20, 2009 | Car Audio & Video
Can you help
I'm assuming here that these are the only wires and that you've already connected the antennas, if any.
Red should go to a constant 12 volt power source, black should go to ground(earth), and blue should go to ignition switched 12 volt power.
Feb 21, 2008 | Car Audio & Video
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
