Question about Poulan Pro 22" Self Propelled High Wheel Mower
Lawn mower timing is messed up
Timing is whey off
  • Poulan Master
  • 2,239 Answers
Are we talking ignition timeing or valve timeing? if it is kicking back on the starter rope it has probably sheared the flywheel key ( has the mower blade hit somthing in the lawn ) also iof the blade bplt is loose this will also cause it to kick back.
Posted on Jan 11, 2013
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
My Lawn Mower does not stop when I remove my foot from the forward direction foot pedal.
sticking check valve they probably messed it up try to bleed air out
Oct 02, 2014 | John Deere Garden
WHEN I MAKE A RIGHT TURN WITH MY HUSQVARNA RZ5424 IT JUST MAKES A GRINDING NOISE AND DOES NOT GO WHAT COULD BE MY PROBLEM?
Where is the grinding sound coming from??? Could be your hydrostatic transmission. When one side goes the other will follow... Time for a new mower... Mine lasted 3 years...
Jul 29, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Can i stretch the spring to adjust the governor
No that will not adjust your speed the governor is there to protect from overspeed and give more power when required like heavy grass cutting,it is operated by air generated by the cooling fins or internally...so don't mess with the spring.. Good luck
Jun 28, 2014 | Toro Power Lawn Mower
Kept blowing fuses, but put aluminum foil on the fuse it worked but cut off,did i mess something up?if so what?
im sorry i dont know much about lawn mower fuses.you might need two take the foil off and find the right fuse.you should have a shop help you with that.
Aug 09, 2013 | Ariens Riding Lawn Mower. Zoom 34 in. 14.5...
What is wrong with a toro push mower when the pull cord hangs up will not pull out
Pull plug, see if worked. To munch fuel some times. Next pull recoil assembly the spring may messed up.
Mar 11, 2012 | Toro Power Lawn Mower
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy....
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
117 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
