Question about Drills
How to remove spindle pulley on craftsman model 113.213150
SOURCE: replacing parts on mower deck
I did sign up for the preminum plan but got no response.
Posted on Jun 11, 2009
  • 138 Answers
SOURCE: Craftsman 42in mower deck spindle breaks and Strips.
there are thousands of these mowers out there, and most people do not have the problem that you are experiencing - let's face reality, you are hitting something, that's the only way these break - it is impractical to make a machine that will mow through rocks, stumps, and water pipes and not break - also, sears does not MAKE anything, they contract companies to make products for them - if you want a thicker, tougher mandrel housing, log onto www.amcpartsstore.com. they recently began offering a heavy duty version of the mandrel housing, part no. 130794. i've seen these and they are definitely beefy - just be sure to put everything together correctly and tighten all the nuts and bolts firmly, and try to avoid the rocks and stumps
Posted on Aug 26, 2009
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
miket756
  • 2702 Answers
SOURCE: spindle pulley will not stay on
try putting some nail varnish on the nut threds to lock the nut up,,,,(pinch some off the wife?) it works just fine, or change the nut for a nylon lock nut,,,
that cost money,,,
Posted on Mar 27, 2010
  • 640 Answers
SOURCE: how do you remove the
Before you put the socket on the nut on top of the pulley, you need to take a piece of wood and place under the deck in such a manner as to stop the of the blade when you turn the nut. You can also use a set of vice grip locking pliers or a large c-clamp to stop blade rotation also by clamping to side of deck. Then you should have no difficulty removing the nut from the spindle releasing the pulley.
If really helpful, please rate.
Posted on Jul 13, 2011
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
Need to replace the star assembly that you attach mower blade to
You need a blade spindle or some call it a mandrel. Some remove the base to replace the spindle, but It's much easier if you drop the base to the lowest setting, loosen the nut for the pulley that is attached to the spindle. I didn't mention taken the belt off because it can be done without removing the belt. once the pulley is removed there are 3-4 bolts holding the spindle from the top of the base, take these bolts out and the spindle will come out. Not sure where you are from, but the cheapest i have found is EBAY. These are new, but a local ACE or somewhere like this may have it in stock.
Apr 06, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need to remove pulley from spindle to replace shaft on craftsman driving mower 42'' deck
Sep 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drills Logo
90 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
