Question about Epson Aculaser C1100 Printer
EscapeSupplytool quit unexpectedly dialog on EVERY print job
Everytime I print to the Epson Aculaser C1100 (in Mac OSX 10.5.6) with the latest Epson driver (40Aes) I receive this most annoying error dialog box - The application escapeSupplytool quit unexpectedly. The dialog interrupts all other applications and the Epsonstatus monitor 3 (the source of this error) proceeds to chew up 90% of cputime. I repeatedly kill (force quit) the Epsonstatus monitor 3 but it creeps back.
I've thought of replacing the Epson supplied driver with the excellent Gutenprint drivers but guess what, it doesn't support this printer.
Any ideas??
Thanks in advance,
Bill...
  • fixya21 Jan 23, 2009
    Thanks for the proposed solution. Have tried this before and tried it again with no result.
    A workaround that I discovered (a moment of inspiration): the Epson laser was run as a network printer through an airport express box. So why not connect the laser directly to an iMacs USB port using the same driver (4Aes) and see what happens. Bingo, the error dialog doesn't materialize EVERY time I print. It appears that Epson's printer driver destructively with Macs airport express network.
    Bill...
    President:
  • 2,559 Answers
Try these methods, one by one, until the problem disappears:
1. Relaunch The "unexpectedly quit" dialog box contains a Reopen button. Click on it to launch the application again. With luck, the crash will not recur.
2. Safe Relaunch If the crash does happen again, curse your luck and wait for the dialog box to appear again. You'll notice that it's slightly different now--there's a Try Again button instead of a Reopen button. Click on it to launch the application in Safe Relaunch mode. When you do this, OS X replaces the application's preferences file with a new file.
Applications use preferences files to store the changes you make to application settings--via the Preferences dialog box, for example. But if preferences files become damaged, they can precipitate a crash. (Preferences files are stored in your user folder/Library/Preferences and are typically named after the application they belong to--com.intuit.quicken.plist is Quicken's, for example.)
If Safe Relaunch eliminates the crash, quit the program (File: Quit). At this point, another dialog box will appear and ask whether you want to keep the new settings or revert to the original ones. Keep the new ones and reset any custom preferences--if this puts an end to the crashes, it's a price worth paying. If you decide you want to go back to the original settings--perhaps because you discover that switching preferences files ultimately didn't help--you can still return the original .plist file to active duty (see "What's Your Preference?").
If a Safe Relaunch doesn't stop the crashes, it's time to move on to a time-tested set of potential fixes. These are worth trying not only for crashes but also for almost any other odd symptom you may confront. Try them in order until one works.
3. Restart Your Mac Select the Restart command from the Apple menu. It's amazing how often this simple act resolves a problem. If the crash is so bad that you can't get Restart to work, press and hold your Mac's power button until the machine shuts off. As a last resort, turn off your Mac by unplugging the power cord.
4. Check for Conflicts and Bugs If the troubled application is not Apple software, make sure it doesn't have a conflict with the version of OS X you're using. For example, if you just updated to a new version of OS X, you may also need to update the problem program. Check the company's Web site for details. While you're there, check to see if the site has a support section. You may find that your problem is common enough that the company has posted a solution.
5. Log In as a Different User You've installed new programs and you've tweaked preferences--is it one of the millions of changes you've made to your system that's giving your Mac an error? You can find out by logging in as a different user. If you've never created a second account, now is the time to do so (see "Diagnose a Sick Mac").
If the crash doesn't occur when you're logged in to the other account, the crash's cause is a file in your user folder, rather than a more general issue with OS X. Accept this as good news, since it usually means that the problem can be fixed without something as drastic as reinstalling all of OS X--or erasing your entire drive.
The cause is most likely a corrupt or conflicting file somewhere in your user folder's Library folder--either a preferences (.plist) file, a font, a cache file, a plug-in, or some other support file (often found in the Application Support folder). You can use utilities to isolate the specific cause. For instance, check for corrupt fonts with the Validate Font command in OS X's Font Book utility, use Jonathan Nathan's Preferential Treatment to identify corrupt .plist files, and delete corrupt cache files with Northern Softworks' Tiger Cache Cleaner (see "The Mac Medicine Cabinet" for details on these utilities). Ultimately, it might just take some old-fashioned trial and error to ferret out the culprit.
6. Use Disk Utility If your program crashes on launch and no "unexpectedly quit" message ever appears, go to /Applications/Utilities and launch Disk Utility. From here, select your startup volume and click on the First Aid tab. Then click on Repair Disk Permissions (see "Seeking First Aid" for instructions).
7. Reinstall the Program Still stuck? Reinstall the program, using the Installer utility that came with the program--otherwise, you may not properly install key components of the software, and that in itself could be the cause of a crash.
8. Check Console Logs Launch OS X's Console utility (/Applications/Utilities). Click on the Logs button in the toolbar. From the list on the left, locate the CrashReporter folders (in your user folder/Library/Logs and in /Library/Logs). In these folders are logs for every application on your Mac that has ever crashed.
Find the log file with the name of your problem program and select it. The output you'll see here is too technical for most people. But occasionally you'll find a clue to the cause of the crash--for example, a reference to a problematic plug-in. Look carefully at any section with a header including the word Crashed (such as Thread 2 Crashed). By the way, when you get an "unexpectedly quit" message, if you simply click on the Report button, you'll immediately get a view of the relevant log file.
9. Reinstall OS X If your sleuthing work has not paid off, it may be time to bring out your OS X Installation DVD and start from scratch. Select the Archive & Install option. If this installs an older version of OS X than you are currently using (such as 10.4.0, when you are now running 10.4.4), use the Software Update preference pane to immediately update to the latest versions of all Apple software.
Please take time to rate this fixya solution.
Posted on Jan 22, 2009
  • 535 Answers
There is ur driver problem so remove it & download fom your printer driver Epson Aculaser C1100 & reinstall it
    President:
  • 1,952 Answers
Try re install soft ware
  • 5 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 22, 2009
    Ensure you use the correct drivers - the C80 ones print gibberish
    via the server despite working fine when directly connected via
    USB.
    The print server can used used either on the WiFi or wired Ethernet
    (I use the latter as it's sat on top of my ADSL Router)."
    McAfee installs
    a re-director that essentially kills off the AIO being able to scan
    or fax across the network. USB is fine, but connecting via Ethernet
    (wired or wireless) is a disaster. This means you cant use the menu
    on the AIO to initiate scans and you cant use the pc to initiate
    scans or faxing. CA has a work around where you have to go in and
    add all the HP apps and allow them. McAfee didn’t offer that
    because of the re-direction service
    error comes when you power up the printer. The noise of the "warm up"
    is the black rubber transfer belt on the Photo Conductor Unit spinning
    through one rev to check for a little silver square on the edge of the
    belt. You can turn the belt manually to see this square.
    If this square is not found, Epson will tell you to throw away an otherwise fine PCU.
    Solution:
    a) Remove PCU and check the transfer belt for the square. Clean WITHOUT alcohol.
    b) check the sensor that reads this square - a small black oblong "camera" in the heart of the printer on the LHS. Clean.
    c)
    If the square is damaged, replace with a piece of tin foil. Superglue
    on carefully, making sure all the edges are glued but not your fingers!
    You don't need to put the new square in exactly the same place, just above or below on the belt is fine.
    Unfortunately duplex printing is not supported on windows vista
    environment, softwares were not updated since product is already
    discontinued.
    C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
    You need to remove the cyan cartridge, and thoroughly clean the inside
    of the printer (please use proper printer cleaning kit, not a damp
    cloth!). The sensors can get crudded up with loose toner inside the
    machine.
    President:
  • 1,990 Answers
Welcome to Fixya! Have your Tried Unplugging the Cables and Power from the Printer for 10 Min. Uninstall the Printer Software and Reinstall the Printer Software, Connect the Cables and Power and Print a Test Page??????????
  • Travis Humphries
    Travis Humphries Jan 23, 2009
    Thanks for the Heads up! You learn new things every day! I really hope that you can get that thing workin!
My printer only prints one copy at a time
I would try updating your printer drivers and also check you have the latest version of whatever PDF software you are using.
Mar 20, 2014 | Epson Aculaser C1100 Printer
Epson c1100 showing 'offline'
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 10, 2011 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Feb 15, 2010 | Epson Aculaser C1100 Printer
Epson aculaser c1100 not printing right hand edge
The problem may well be that the drum needs cleaning. There is a plastic flap on the rhs of the machine. Open that and you can pull a long lever out. You also need to let down the front cover and pull out the lever on the right hand edge that faces you. Then extend the long lever at the side as far as it can go and push it in and out a few times. This should solve the problem. Put the front lever back and close the cover. It took me ages to find this - Epson are not good at highlighting it,.
Oct 22, 2009 | Epson Aculaser C1100 Printer
Install Photo Conductor
Perhaps, it is necessary to establish the necessary software.
http://filters.atspace.com
Aug 10, 2009 | Epson Aculaser C1100 Printer
EPSON C1100 JAM ON MP E SITE
Solution to this can be found here: http://www.tradebit.com/filedetail.php/2366766-epson-aculaser-c1100-jam-mp-e-countermeasure
The printer has a modification kit for this error which is caused by a weak solenoid
Nov 09, 2008 | Epson Aculaser C1100 Printer
Epson C1100 Aculaser Duplex unit not recognised by Vista
I have had the problem, but it is easily fixed in Vista.
1. Click Control Panel
2 Click Printers
3 Right click your AL-C1100
4 Click Properties
5 Click Optional Settings label
6 Click - "Update printer info manually"
7 Click - "Duplex Print Unit "
8 Click Settings
9 Tick box in bottom left hand corner - "Duplex Print Unit"
10 Click OK .... exit
Sep 12, 2008 | Epson Aculaser C1100 Printer
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Epson AcuLaser C1100 - rainbow stripe
could be the photoconductor. see this post below, also try cleaning the print head
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Jan 18, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
