Question about Altec Lansing ADA995 Speaker
ADA995 on Macbook Pro
I want to run the audio of my Macbook Pro through my ADA995. Is there an external device that would make a simple one plug connection that I could set up?
SMC problem on my MacBook Pro. It's and early June 2011 model. I used it one night to pull some videos off an external I had and it was running really Hot. So I decided I would finish uploading them i
Apple issues SMC update for MacBook Pro systems
Apple has released a firmware update for MacBook Pro systems that addresses a problem with sudden shutdowns under low battery conditions. Here is the article--> http://reviews.cnet.com/8301-13727_7-57322800-263/apple-issues-smc-update-for-macbook-pro-systems/ Here is the Firmware update page. http://support.apple.com/kb/DL1474
Dec 03, 2012 | Computers & Internet
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
How do you use the simpletech 160 gb ext drive with a macbook pro or a macbook
Your external HDD must be MAC OS compatible.
I've it is compatible, just plug it in and it should pop-up
Jun 08, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Error
That error code means your HDD is dead..
It may be corrupt; it's unusable.
You will need a new SATA HDD.
Source: Google and my experience with that error in my Macbook Pro. var fctb_tool=null; function FCTB_Init_c051884345bf42a4a9c154223e7d2f63(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c051884345bf42a4a9c154223e7d2f63(document['FCTB_Init_6e224391880b406abfb85fe687432776']); delete document['FCTB_Init_6e224391880b406abfb85fe687432776']
Jul 06, 2010 | Apple MacBook Air
My on board audio output stopped working last night on my macbook pro. i've gone through system preference/sound and audio and everything is set appropriately...can you help me fix this?
Reset the SMC and PRAm and check.Update the OS also.Check with a saperate external OS loaded HDD.This can help the issue.If not then the issue is suspected with the logic board
Mar 09, 2010 | Apple MacBook Pro Notebook
Sound on Windows XP
well apple is apple dont question on that, need to find company sound card driver.(Intel HD Audio ), try these driver syte:
www.downloadcenter.intel.com/Default.aspx
Jan 16, 2010 | Apple Macbook Pro, -2.4GHz Intel Core 2...
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | Apple MacBook Pro Notebook
How to get video and audio from sony dcr pc2e into macbook
you should be able to use firewire and iMovie to get the video over in DV format
Mar 15, 2009 | Sony Handycam DCR-PC2E Camcorder
Altec Lansing ADA995 Speaker Logo
46 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
