Question about Home Security
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
I sent the DVR back to the supplier and this was replaced and I got the same problem, I sent the Seagate 300GB HDD back and this was exchanged for another HDD a 300GB Western Digital. The problem still remains with both the DVR and HDD being replaced, I use the system but cannot record can you advise what can be done to rectify the problem
  • 7 more comments
  • Peter Field Jan 21, 2013
    Thanks for the reply Ian but it is a 3.5 sata Seagate barracuda 500gb internal drive, ....I have used disc wizard to zero the drive and still same result...I have done a format via windows 7 and still get the same result
  • Ian Ball Jan 22, 2013
    Hi Peter.... Sorry, I should'nt have assumed anything about these units.
    I am working on a neighbours 8ch sunluxy. Rather unfriendly little beasty! So you have zeroed and formatted the drive on a win7 pc so the drive is fine. This unit formats to FAT32 so yours should too. Have you tried different jumper settings on the drive? (Master, Slave, Cable select or even remove all jumpers?) The only other thing I can think of off hand is do you have spare sata cables possibly from an old pc motherboard to try. If all that fails, then I would be inclined to think the second unit is faulty as well..... Stranger things have happened! I'm sort of out of ideas right now.... but I will keep an eye on your post and keep an ear out for any new info or ideas. Good luck!
    Sorry again... forget what I said about the jumpers... sata drives don't use them basically so there may be pins but no jumpers fitted!
  • Peter Field Jan 22, 2013
    Yep I am baffled have sent unit and drive to someone who knows what to do, let's see if it cracks it
  • Loz Watson May 29, 2013
    Hi,i read somewhere that this system only supports 320gb up to 3tb,try bigger hd,i may be wrong.
  • Robert macfarlane Aug 11, 2013
    I have a sunluxy CCTV but need the code for it can anyone help
  • scott cadden Oct 04, 2013
    have sunluxy but night camera is snowy picture anyone else have this problem
  • david
    david Apr 28, 2014
    Hi. I have a 4 channel Sunluxy H.264 DVR with 1TB WD hard drive, and it doesn't work with internal HDD. and there is a message : HDDs Not found. also I changed HDD to 80GB but doesn't work again.
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Posted on Aug 23, 2013
  • Meric Little Sep 24, 2013
    HI Patrick, I have a WD10 EZEX 1TB HDD 64mb cache for use with same sunluxy dvr. After initial installation and formatting of drive all worked ok. Having turned of the dvr to complete fitting of cameras. When I restarted the dvr it gave me the HDD not found message. Do I need to do as you have suggested and how would i go about changing it to a 8mb cache? All help gratefully recieved. Thanks Meric
  • Kerrie Breton
    Kerrie Breton Jan 13, 2014
    hi i've searched for these hdd's but most of them seem to be 16mb cache, wondering why you have said it's important for it to be 8mb cache???
    New Friend:
Hi Peter.
Sounds like you are trying to record to a USB hard drive. Open the dvr box and fit a (preferably) 3.5 inch internal hard drive with a sata connection. The machine should then find the drive and ask if you want to format it.
Hope this Helps.Cheers.... Ian Ball
Posted on Jan 20, 2013
    Now I need a username and password how do I get that sorted
Im having the same problem...initially the sunluxy DVR registered my newly bought Hitachi 320 gb HDD.. I formatted it and now I get the same messaged every time I turn it on??? cannot find HDD?
Posted on Feb 13, 2014
    New Friend:
Posted on May 29, 2013
  • bill deere
    bill deere May 09, 2014
    HI..have had several messages ..no hdd...but finally found that the sata lead at the board was the issue...taped the sata lead to the body/shell as to hold it firmly in place...using 1 TB wd hd..64 mb cache... no more dramas..
2 Suggested Answers
dttech
  • 4803 Answers
SOURCE: Tsm Dvr8024 W/500gb 4-ch H.264 Digital Video Recorder Manual
Keven,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Posted on Dec 17, 2011
I hook up swan camera to h.264 dvr and no picture shown . What wrong don't know please help
make sure that the DVR system is PAL and the resolution is 720p
Mar 02, 2015 | Home Security
How to set up system to be able to see cameras away from home?
With the RJ-45 Connection, up to 5 users can simultaneously monitor remotely from anywhere through LAN or Internet. do you have it set up this way?
Nov 30, 2014 | Digital Peripheral Solutions 8-Channel...
X pose 4 ch h 264 dvr not working
Depends on how much wire you have left to work with?
Aug 16, 2014 | Homeland Security Cameras Homeland...
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Jun 07, 2014 | Night Owl Optics Night Owl Scorpion 168500...
My H.264 Network DVR resolutions are not compatible with mt Monitor. How do I reset the resolutions manually ?
You may be lucky because the battery acid may not have gone beyond the contacts in the battery chamber: open battery chamber and clean out especially at the bottom of the chamber and blow out any loose stuff when you finished cleaning ( use pencil erazor or something similar , but do not use sand paper or anything that will damage chrome plating of the contacts ; you do not want corrosion at later stage ).
Sep 16, 2012 | GW Security Professional 4 Channel 1t Hdd...
DVR Video Loss
Charter was out and changed modems, after that I noticed we lost signal.
Aug 16, 2012 | QPS Q-See QSDR008RTC-500 8 Channel H.264...
Home Security Logo
7,155 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
