Ice and water under and in deli draw plug clean but still freeses replaced heater strip
SOURCE: water leaking under frigerator on the left side
HI,
your drain is clogged. you may have a catch for your drain where you see leak coming from. that may pull off and you can see if their is trash build up in it. you are going to need to take the panel off the back of freezer. inside back of freezer you will see screws. they will need to come out, If you have ice maker that will need to be removed also. once back panel is off you will see your coils beneath the coils it will most likely have a sheet of ice. turn machine off and take a hair dryer and defrost the ice. once ice is gone take a cup of hot water and run thru drain to see if unclogged. repeat if drain is not clear. the ice in drain tube will eventually un clog. use a steamer. much quicker.
any further question let me know.
SOURCE: GE Profile side by side...water collects under the
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: water freezes around coils and stops fan motor
Check for a leak in the water dispensing tube for the ice maker. If there is a leak you can use plumbers tape to seal it off.
Otherwise, tell me more about where your Fridge sits? What's around it?
SOURCE: Like others, our fridge (GETFX25/VPBSWW) defrost
try "haier" the worlds 4th largest manufacturer of white goods.spares are cheap too (made in china)
SOURCE: My GE refrigerator model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
