My p4vmm2 motherboard is not beeping,, but the fan in the powersupply and in the processor is running.. how can i fix that???? and it is not booting,, and there is no display in my monitor???,, plsssss,, help me,,,,,,,,,,,
I lost my manual. Help me to get the layout of the motherboard. I need to reset the bios but could`nt find the jumper. I lost my manual. Help me to get the layout of the motherboard. I need to reset the bios but could`nt find the jumper.
AnonymousMar 19, 2008
where is the mb reset where is the mb reset
AnonymousApr 25, 2008
P4VMM2 same problem as jherry...P4VMM2 same problem as jherry...
You can't post conmments that contain an email address.
Is there any fan noise or beep codes or any sign its powering up>
check to see if the powersupply comes on with fan..then chk for processor fan and video next.
most gateway have OEM power connection that is not compatible with other supplys
chadman
Hello, Switch off the pc . Remove cmos battery press on off switch for few seconds and install it again. Please install another SMPS for cheeking.
Shibuda, If you are helped you can rate on the 4 thumbs and leave a short comment,because, this is the free side and I can get the chance, to help people like you .
No beep or sound means Motherboard Defective, aside from Processors is OK, Memory is OK, and the rest! Buy a new one not as the same Motherboard you use. ASROCK Motherboard are have a a problem when high temperature occur.
If i am helpful to you, please rate me. Thank you.
The motherboard LED is supposed to glow, indicating that the board is residually powered, after disconnection of external power and as a warning of this condition so that you will not further disconnect or connect any peripherals until the charge on the power retention capacitor is properly dissipated.
The Power Supply and Processor Fans should only run while power is applied, and if the Processor fan is always running at a high, possibly noisy, velocity, additional Processor Cooling may be necessary by means of a higher efficiency heat dissipation system.
If you remove memory from the board, the system should not initiate, as memory has little or nothing to do with the problems you cite, but everything to do with the proper initiation of your system.
Buy a larger Processor Fan Assembly and those symptoms you cite which actually are problems should cure themselves, while those symptoms you cite which are not problems will still not be problems.
have u checked the power supply and all of its connections and the system board fan to make sure they are operatring correctly and also is the beep code a straight 5 beeps or is sthere any thing else kplease let me know so i can try to give you some more help
It's ok to upgrade the processor to P4 the mother board is capable to run the pentium 4 2.0Ghz only . I said that because i'm using that type of motherboard ecs p4vmm2 with processor 2.0Ghz. But for my opinion the problem of your friend computer is not the processor is about the cooling fan heatsink because if the heatsink is not fit or properly lock the processor is over heating that's why the computer hanging and shutdown. If you can tight the two clip that was broken the problem is solved because i have also the same problem before one of my client computer. but if you friend want to upgrade to p4 it's better to buy also a new fan and heatsink for P4.
Disconnect all the disks and CD, remove memory and everything else including all the added card (Video, network,etc..).
Power up with processor only and if you don't hear any beep you have a bad motherboard or processor.
If you have any beep power off and add the memory and try again. Keep adding one component at the time until you discover wich one is creating an issue.
PS Did you verify compatibility between motherboard and processor?
there is no changes,, is there a chance for my mobo???,, huhuhuhuhuhuhu,,:c
