Question about Garden
My mower revs up and down
Honda 160 self propelled lawn mower
  • 2,239 Answers
This is a case of partially blocked jet in the carb, you need to remove and clean the carb, or remove and get it cleaned sonic cleaned by your local dealer.
Posted on Jan 11, 2013
canbruce75
  • 1776 Answers
SOURCE: Racing of a Honda 160 CC lawn mower engine
When a small engine "surges" in all speed ranges the possible causes are:
*Dirty air filter
*Water or contamination in the fuel system.
*Breaks in the spark plug wire (leaking), loose or corroded terminal connections causing an intermittent failure.
*Misadjusted or malfunctioning governor.
Problems with surging only when under load or at idle are likely caused by carb blockage or misadjustment.
Hope this helped and good luck to ya!
Posted on Jul 20, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
  • 93 Answers
SOURCE: Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Posted on Sep 15, 2009
HOW DO I REPLACE THE SELF PROPELLED ON MY HONDA MOWER. MODEL HRX217HXA
http://www.lawnsite.com/showthread.php?t=281234
Good pictures on this link to follow. I found it eaiser if you put your mower on a work bench or 2 sawhorse with plywood on them. Read everything on the link for your plan before you start. When you finish you will feel you can fix anything on the mower. Hope this will do the trick for you. Good luck!
Sep 21, 2014 | Honda HRX217VKA Lawnmower
Honda gcv160 what should the spark plug gap be?
For a Model HRR2163TDA 5.5hp.(GVC 160 Honda)..it is .028 - .31 in Don't know what model you have ...would assume about the same...I am not an expert
Sep 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the spark plug on an MTD self propelled 123cc lawn mower?
Look in front of engine. Your see rubber coated wire. Unplug it, and there your plug.
Jun 03, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to speed up motor on yardman self propelled lawnmower
You could disconnect the governor linkage at the carburetor and just connect the throttle cable (if it has one) directly to the butterfly plate on the carb. Aftermarket throttle cables (one size fits all) for push mowers are available. If you go this route, be careful not to over rev the motor (esp. when not under load) as you could possibly throw a rod or float a valve.
Aug 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Oct 01, 2009 | Garden
Jun 26, 2009 | Garden
Apr 29, 2009 | Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
