Question about Samsung HCL4715W 47" Rear Projection Television
I just bought a Samsung 47" Rear projection TV second hand from a neighbour who says it was sitting in his basement for years doing nothing. When I plugged the TV in it at home it was working fine ini
4 Suggested Answers
  • 1056 Answers
SOURCE: Samsung Rear Projection 47" TV goes into stand by on start up
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
Posted on Jun 27, 2009
SD Tech
  • 14553 Answers
SOURCE: Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
Posted on Nov 24, 2009
  • 416 Answers
SOURCE: Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Posted on Mar 18, 2010
My samsung 47 in projrction tv has blue gosting or a blue double
Thats usually related to the convergence Ics and the 3.9 ohm resistors needing replacement.
Jan 23, 2010 | Samsung HC-P4752W 47" Rear Projection...
Greenish haze on my Samsung HC P4741W
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
Feb 14, 2009 | Samsung HC-P4741W 47" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Samsung Rear Projection TV - Only Green and Yellow Color
What is the "bulb" part Number ? Please verify Model #.....T.
Dec 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
