Question about HP ProLiant ML370 G5 Server
HP proliant ML370 orange light glowing not start
sksree406
  • 61 Answers
SOURCE: HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Posted on Oct 31, 2008
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
  • 468 Answers
SOURCE: My HP Proliant ML370 server has no video. Can I
There is standard Integrated ATI Rage XL Video Controller with that server.
Posted on Apr 14, 2010
Mikenet2620
  • 106 Answers
SOURCE: I have a HP Proliant ML370 G3 server which was
generation 3 servers do not support windows server 2008 there are no drivers for this OS
i include the OS Matrix for you to confirm
Posted on Oct 29, 2010
Issue with power button in HP ProLiant ML370 G6 server
If i am not mistaken I belive that there are two power supplies, correct? what if you swap them? Or if you have a spare... I think that maybe either the button isn't working correctly or the power supply might have some issues...I also think there might be some LED lights on the power supplies themselves...check it out.
Jan 02, 2014 | HP ProLiant ML370 G6 Server
Issue with power button of HP ProLiant ML370 G6 server.
I would check the the power supply to make sure they are seated correctly. Also, if you have intalled any new item, check to make sure it is seated correctly. If all are correct, you may have a faulty power supply or the en power outlet may not be correct specs for power needed.
Good luck.
Frank, N.I.T.
Hp proliant ml370 G6 ethernet controller, base system device and IPMI interface not configured properly
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Oct 20, 2012 | HP ProLiant ML370 G6 Server
I need driver of hp proliant ML370 G6
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/swdHome/?cc=us&cc=us&lang=en&lang=en&sp4ts.oid=3884311&ac.admitted=1399271691587.876444892.199480143
May 25, 2012 | HP ProLiant ML370 G6 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
I have a HP Proliant ML370 G3 server which was replaced can it be rebuilt for 64Bit Windows 2008 operation?
Oct 04, 2010 | HP Compaq ProLiant ML370 G3 Server
HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G5 Server Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
