Question about Dryers
Install a attic vent
Want you be the best way or product to use ( novice )
    Novelist:
  • 200 Answers
I know that you need to install the vent but if you can pick a different location it would be better for energy efficiency because of associated downdrafts that may occur. If you can locate the vent to go through a wall to the outside it would probably be better, If that is too big a project maybe consider an indoor venting system. If you wish to use the attic assure that you add a "draft trap" (see link) and assure you clean the dryer vent pipe at least 1/yr. http://plumbing.hardwarestore.com/51-600-dryer-vent-accessories/draft-blocker-inline-damper-602022.aspx
Posted on Jan 12, 2013
What are the metal vents on roof for
It is a passive ventilation system for your attic. Besides the roof top vents, there should also be openings in the soffits. Cooler air will enter through the soffit, pass into the attic, and the heat in the attic will raise. The vents on the roof are to allow the hot air a place to escape.
Mar 16, 2015 | Heating & Cooling
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
When installing an attic fan do the existing air circulating vent fans and the ridge vent have to be removed? dennisa1963@hotmail.com
That depends on the location of the attic fan... if you install it in the ceiling of the house and have it just blow into the attic then the fans up there will be fine to let them there...
heatman101
Jan 25, 2011 | Heating & Cooling
Is there a video on how to install baffles in attic
That is never a clean job, the best way,In the attic clean away the installation from any of your spot, biggest deal is to make sure it returns to the place it was.good luck
Oct 14, 2009 | Subzone B110-ZG Replacement Baffle/Grill...
Hi My extractor hood in the kitchen has a hose that goes into the kitchen roof then out through the roof vents. The problem is that all the cold and wind comes back down the hose and makes the kitchen very...
You need to install a damper. It sounds like your vent now just vents into the attic and out the attic vents. If that is the case, or even if it vents directly to a roof vent, you can install a damper that only lets air flowe one direction.
rewilliams_2068_131005279
springload.gif Here is just one source of many that you can purchse dampers from.
http://www.rewci.com/416splobada.html
The damper would be installed in the exhaust duct. If your vent pipe is connected to a roofmounted vent, you can replace the vent with a dampered vent.
Aug 30, 2009 | Bosch 22 in. PCD685F / PCD685D / PCD682D...
My Panasonic FV-11VQL2 seems to have the damper stuck in the closed position. The fan does not exhaust well, ever since we got a new roof (vent and 4" duct too). Any way to unstuck it without going into...
Hubby went into attic. The roofer did a poor job installing the new 4" duct and roof vent; duct was poorly attached and pinched at both ends. He redid both connections, and now the fan works well----no more foggy, drippy mirrors!
So, the fan is fine------the installation of the new roof vent and duct was shoddy.
Aug 24, 2009 | Panasonic Dryers
Mouse in vent fan?
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Advantium 120 Convection/Microwave Oven
Filter,heat ducts,and best heat we can get from unit
As for a filter if there was one installed it will be somewhere between the unit and the inside livingspace and are the black plastic supply vents wrapped with insallation or not ,if not they are the wrong ducts if you need more help just e-mail
Nov 10, 2008 | Ruud UBHC Air Conditioner
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
