Question about Digital Check TellerScan 240 Scanner 50 DPM [N-TS240-50]
Red light on tellerscan 240 - Digital Check TellerScan 240 Scanner 50 DPM [N-TS240-50]
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
On the Mercedes C-240 the oil sencor light came on with the A service oil change .I had the oil changed and now the oil level light comes on. And this is on a 2005 C-240 4-matic .
Could be the person who changed it never ran the motor and then topped it off once the filter was full. Have you checked the oil level after you let the car sit overnight to make sure the oil level is on full? I would say it could be a bad oil level sensor, except that the coincidence of coinciding with an oil change is too obvious.
Sep 14, 2014 | 2005 Mercedes-Benz C240 Classic
Power needs for electric cooktop
red is for 240 volt. most dryers are 240. what does elec plug in look like?? like a regular 110 v plug? or a lot larger? if large plug its a 240 v dryer.
Mar 09, 2014 | Dryers
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
My plantronics explorer 240 its dead, when i to charge the red light flashing, but dont charge.
If your headset is not charging, then the battery has breathed its
last breath. Now's the time to take a look at what's new on the
attached link for Plantronics bluetooth headsets.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Sep 15, 2011 | Plantronics Explorer 240 Bluetooth Headset
How do I turn it on. Is the red showing or not showing
To turn the Explorer 240 Bluetooth headset on, press and hold the call control button until the indicator glows blue. You will hear ascending tones. The headset will then show intermittent flashes of blue. You should only see a red light when powering the headset off or if you are charging the headset you will see a solid red light. User guide is included in this link.
Plantronics Explorer 230 User's Guide
Aug 03, 2011 | Plantronics Explorer 240 Bluetooth Headset
I am wiring a 240 volt, 30 amp 2 pole receptacle for a construction heater. I am using 3 wire romex. i hooked up the ground, red and black wire and capped to white nuetral wire. i hooked up the red and...
Thank you for posting your question here on Fixya.com.
The only thing that would make sense is you have the two lines somehow on the same bus bar in the box or a supply issue either to the sub-panel or in it. When you power up the circuit are you getting 120 or 240 across the red and black wire? Double check the 240 in the sub panel if you only get 120. If you are getting 240 all the way to the heater then you are missing something within the heater or its instructions.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
John
Jan 04, 2011 | Hammering
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
VT-240
the vt-240 came without instrutions where can i get them? my email address is banjo0088@hotmail.com thank you
Apr 29, 2008 | VXI Corporation VT-90 Digital Voice...
Electric stove lights work but nothing else
sounds like the range is not getting 240 volts. When it only gets 120 volts lights will work but no heating element will. You need a volt meter and make sure that you have 240 volts across the black and red wires. From black to white and from red to white you should have 120. If you find you have a voltage problem you need to check your fuse box. you could have a fuse out or a circuit breaker can also be bad
Jul 24, 2007 | Whirlpool RF302 Electric Kitchen Range
Digital Check TellerScan 240 Scanner 50 DPM [N-TS240-50] Logo
1,475 people viewed this question
Top Digital Check Office Equipment & Supplies Experts
john h
JonSnell Electronic
JonSnell Electronic
Terry
Terry
Are you a Digital Check Office Equipment and Supply Expert? Answer questions, earn points and help others
