Question about Audioline Lands Phones
Amplcom pt 580
Recently purchased PT 701 to go with PT580,Having problem registering additional handset to base station.I am 77 yrs old with poor understanding of modern technology and jargon. Instructions not clear to me, buttons listed in manuals are not identified on phone,ie what is the page button. Can someone please help with clear,easy detailed instructions. Have avoided phone contact with Amplicom because I feel uncertain about dealing with technical stuff by phone. (was advised that PT701 was compatible with PT580) Yours in hope Robin Dorling
  • 3 Answers
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on gorbuz@yahoo.com
Posted on Nov 04, 2008
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Posted on Feb 19, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
SOURCE: handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Posted on Apr 30, 2009
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Additional handsets will pick up calls from mobile phone but not landline calls
Try registering your older handsets with your new base station per the manuals instructions. Also your new base station might be transmitting on a different frequency or some other coded transmission is not recognized by your old handsets. Did the manufacture say the older handsets would work with the new system? They might not even if they did say so.
Jan 09, 2014 | Avaya 3920 Phone
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Initializing
The hand-sets are not registered with the base-station. Reset system by: remove batteries, unplug base station, disconnect batteries in all hand sets. Wait 15 minutes. Reinstall batteries in hand sets. Reinstall batteries in base station, plug base station in. Place each hand set in the base station until it automatically registers (usually immediately, or within 1 minute or so).
If that doesn't fix the problem, if possible, return the system to where you bought it for exchange or refund. If that isn't an option, call Thompson help line. They are not particularly knowledgeable, but will authorize a return to the a repair center. The process is slow...
My experience: The two hand sets that came with my system worked perfectly, but none of the three additional handsets I purchased would register. The three additional handsets I purchased were the last three on the my retailer's shelf, so, retail exchange wasn't an option. I contacted Thompson and they authorized return for repair or replacement. The repair center received my handsets on October 29, 2008. Its now November 27, 2008 and I'm still waiting.
Mar 03, 2008 | GE 28128EE2 Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Registering a new phone
With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
Jul 10, 2007 | Uniden Cordless Phone
Lands Phones Logo
16 people viewed this question
Top Audioline Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Audioline Lands Phone Expert? Answer questions, earn points and help others
