Question about EliteGroup P6SET-ML Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Researched Intel site identifed the motherboard through the AA #'s. A81583 at Intel 845 GRG board. Problem is the front panel header connectors do not match the source document supplied on the Intel site. Board had top row: 4 connectors 1 empty 1 connector 1 empty 1 connector. Bottom row: 8 connectors.
  • harleysnake Mar 05, 2009
    map9966:
    I have the D845GRG that I just purchased from Ebay. The board will do nothing wil not power up/no fans/no beepcodes. If I jump the green and black wires on pwr supply cpu fan spins and green led on mb, but no beep codes. The MB is not like the GRG manual. There is no AGP slot. and front panel header panel has 16 pins,10 & 14 empty. I think this was a pull from a Gateway Emachine. The seller say's it was from a working system. I assume it is a modified board for Gateway, so soes that mean I need a Gateway case to bring up this board?
  • Anonymous Mar 12, 2014
    motherboard front panel
    President:
  • 2,351 Answers
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Posted on Jan 22, 2009
I am looking for a wiring diagram for the mic in, mic power and mic ground on a gigabyte motherboard 8vm533m-rz
"The front panel audio header on an Intel® Desktop Board lets you connect to a front panel audio module built into a system chassis. This document describes the header pin-out configuration for connecting a chassis with Intel® High Definition Audio (HD Audio) or AC'97 audio.
Note HD Audio headers are pin-compatible with AC'97 chassis and connectors. "
-intel Desktop Boards Front Panel Audio Header Pinouts
Sep 22, 2014 | Computers & Internet
Diagram and pen out power supply and power switch placement emachine t3828
The eMachines T3828 Desktop PC uses an Intel D845GVSR motherboard.
1) Socket 478 processor socket
2) Comes with an Intel Celeron D 335 processor that uses a Socket 478 processor socket.
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Prescott-256.22_.2890_nm.29
Celeron D 335 / part number RK80546RE072256
3) The motherboard chipset is an Intel 845GV
[The Northbridge chip is an Intel 82845GV, and the Southbridge chip is an Intel 82801DB { ICH4}
Intel 82845GV and Intel 82810DB are the part numbers on the chips]
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_Chipsets
Here is the motherboard manual you requested,
http://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=15210
On this page click on the top file>
D845GVSR_ProductGuide_English.pdf
(Date 07/01/2003)
Go to the right and click on > Download
On the next page left-click on the empty circle to the left of>
I accept the terms in the license agreement
The file will automatically start downloading
Let the file download all the way before looking through it.
Connecting Internal Headers - Page 31 in the PDF file page number box at the top
You want C - Front Panel
The plastic front of your computer is the Front Panel
Cables (Wires) coming from the Front Panel go to the Front Panel header on the motherboard
Connecting the Front Panel is shown on Page 32
Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the Bottom Right. It is right along the bottom edge of the motherboard.
There are 4 pins across the Top
There are 5 pins across the Bottom
The Pins are numbered.
Starting on the Left side of the motherboard going towards the Right,
the Top row of pins are numbered 2, 4, 6, and 8
the Bottom row of pins are numbered 1, 3, 5, 7, and 9
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
Pin 1 goes to the Positive ( + ) wire
Pin 2 goes to the Ground wire ( - )
If the LED is dim after installing switch the two wires around
B) Pins 5 and 7 are for the Reset switch. IF used. (Reset button)
C) Pin 9 is for the 5 Volts DC
D) Pins 2 and 4 are for the Power On LED light
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Page 34 shows you where the power cables from the Power Supply go to the motherboard.
Connecting Hardware Control and Power Cables
D shows you where the 20-pin ATX main power cable goes.
Typical 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
A shows you where the 4-pin +12 Volt power cable goes, (Power for the Processor),
Typical 4-pin +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
B is where a Chassis Fan connects to. (Computer case fan)
C is where the Processor Fan connects to
E is for another Chassis Fan
If you have further questions please post in a Comment.
Sorry it took so long to reply, I just saw this problem.
Regards,
joecoolvette
Nov 01, 2010 | E-Machines (T2958) PC Desktop
Intel front panel connection for D845PEBT2 motherboard i need the diagram for the front panel connection on the motherboard
You'll find the diagram in the manual on page 33, item C.
If you no longer have your manual you can click on the link provided;
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
You will Adobe Reader to view the .PDF file.
Case wire colors vary, unless your case jumpers are marked. Common colors for positive include solid blue, red and green.
Ground - negative color is usually solid white.
Except when connecting an internal speaker, red wire is positive and black is negative.
Hope you find this hepful!
Mike
Nov 02, 2009 | Intel Computers & Internet
Multimedia Audio Controller Needed as Well!
I find VGA and Audio triver for motherboard MSI-661FM3
Jun 02, 2009 | MSI 661FM3-V Motherboard
Conecting front panel wiring to INTEL 845GRG MOTHERBOARD.
Normally a small area of 10 pins or 9 one is not used,you nedd the book or go to manufactuers website and download user manual,connect your wire to the board with out a diagram and you could damage the board
Jan 15, 2009 | Intel D845GRG Motherboard
Intel D845GRG Motherboard Problem:usb wiring conection to board
Hi mrm291048,
The Intel D845GRG MB supports USB 2.0 & is backwards compatible to USB 1.0
For in-depth description of motherboard wire color & location click on this link & scroll down till you see, "Standard USB Cable Wiring Color Code". http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
You'll also need to open your manual to page 68 If you need the manual for the D845GRG MB click on this link; ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
Between the two you should be able to set the correct colored wire up to its matching pin on the MB.
If this is not answering your question, please set me strait & rephrase the question.
Mike
Sep 30, 2008 | Intel D845GRG Motherboard
T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
Steven
Sep 17, 2008 | E-Machines (308714) Motherboard
Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
Feb 24, 2008 | Intel D101GGC Motherboard
EliteGroup P6SET-ML Motherboard Logo
2,390 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
