Question about True Refrigerators
True t-49 temperature control problems
I installed a new 831932 temp control and still have the same problem I had before replacing it The dial is set at 1 or 2 and the temperature will get too cold 25-27 degrees. If i adjust the dial the tiniest bit,( like barely moving the knob), then the temp will go too high . So the temp control is controlling the compressor, but the temp ranges from 26-37 do these temp controls need calibrated?
  • 112 Answers
SOURCE: Replacing a temp control valve on a true GDM 26 commercial refridgerator
Unplug the unit & remove the plate holding the thermostat. The capillary for the thermostat will go into a very small tube that runs into the evaporator coil. You will probably not be able to see the tube but will have to feel for it and get a good orientation for where it is located before you pull the capillary out. Try to measure the amount of capillary in the tube as you pull it out so you know how far you have to push the new one in and put some kind of tape or mark on the new capillary before you try to push it in. you might have to soap up the capillary to get it to slide easier.
Posted on Jul 07, 2009
SOURCE: temperature adjustment
Answer the question is 1/2 or 4/5 colder?
Posted on Feb 04, 2007
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
  • 262 Answers
SOURCE: fridge won't turn back on? after reaching temp control setting.
check for loose connections at temp control and check for bad grounds the problem is in the wiring not the parts good luck and have fun
Posted on Dec 17, 2007
SOURCE: Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Posted on Mar 19, 2008
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
T-49 warm in the morniing, but then works fine all day
Sounds like you are letting the refrigerator sit in an unheated space at night. Those refrigerators have minimum temperature ratings as well as maximum temps. True Mfg. Can be more specific but I say not under 60deg F. Good luck hope this helps.
Apr 09, 2014 | True T-49 Side by Side Refrigerator...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
True t49g side by side not defrosting
True's T-49G is not equipped with a defrost timer as it is a medium temp unit, so I would suspect the temperature control may be defective. Part #800393 is commonly used for the True T-49G, though it's best to check verify with model number and serial number. It could also be as simple as adjusting the temperature dial a little bit. The target temperature range is around 36 degrees Fahrenheit.
May 31, 2011 | True T-49G Glass Door Commercial...
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
Cooling probleums
The thermostat should only control within a specific range of temperatures. I believe your thermostat needs to be replaced.
Nov 22, 2008 | True T-49 Side by Side Refrigerator...
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
True TS-49 Refrigerator freezing food
NEWER T-49 s DO NOT HAVE ANY DEFROST HEATER OR TIMER OR CUTOFF'S All solutions involving repairs on these items are bogus. The defrost occurs when the compressor shuts down normally. During this time,since the fan never stops, it should circulate above freezing air around the coils and a slow defrost may occur. It is a poor system at best, and does not work well if the compressor runs a lot. MY erratic cooling was fixed by removing the copper sleeve and cold control probe from the evaporator(cold coil on top) Polish up the copper tube and the probe, reinsert and bend the copper sleeve very slightly so that it fits snuggly into the evaporator. Mine was very loose and not making good contact with the metal evaporator, giving erratic control of temperature.. Good Luck!!
Mar 16, 2008 | True T-49 Side by Side Refrigerator...
Refrigerators Logo
101 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
