-   I have a veo webcam and I want to use it running windows vista but I can't get a website to download the driver from. Can you help?-   AngelLadyTex
Mar 06, 2009
-   will not down load to my pc with vista-   bigpapa1981
Mar 03, 2009
-   I have the same problem as michael_spra . Also, I'm running Vista. Any Ideas?
-   Guest
Jan 08, 2009
-   doesnt work with vista-   craftyrn1959
Nov 21, 2008
-   I tried the suggestion of d/ling the file and going to properties, blah blah blah... it still didn't work.. says something about DDL not loading ? Sigh.. I have no clue-   Guest
when download is complete, click (open folder)
select the file (veo_330V_v002.exe) right click it
select properties
select compatabilty
put a check in box (run this program in compatabilty mode for)
choose (Windows xp (service pack2)
then apply
the double left click the file
and Bingo Vista will install it
I am using mine on yahoo messenger as I type now!
When download is complete, click (open folder)
- select the file (veo_330V_v002.exe) right click it
- select properties
- select compatabilty
- put a check in box (run this program in compatabilty mode for)
- choose (Windows XP service pack 2)
*Note: Be sure in the general tab, below the 'advance' button that it does not show 'unblock.' If so, click 'unblock' to allow the program to fully install. If you do not perform this action, you will continue to get the .dll error when you try to install.
- now click apply and ok.
Double left click the file and Vista will install it.
Ok! I downloaded the drivers as everyone else said to do and set compatability to XP PRO SP2 and it would not work. So being a computer geek and never letting anything get in my way I went to the original install disk and found the camera install file. I clicked properties and set it to XP PRO SP2 then installed it. It stopped at 95% which worried me then it closed without giving me the DLL error as before. Then I backed out one folder and went to the Software install and set compatability again and installed it. I minimized this screen so I wouldn't loose it and found my desktop Icon and double clicked it and it loaded up. I went to Record a video and low and behold I had video. Not as good as my newer webcam but it works. Now I got my newer cam looking outside on my window sill as we have had some problems out here in the county and will see if I can get both cameras recording/usable at the same time. One for Messenger and one for survailance.
I hope you all have the same results. Just don't take no for an answer and use your past experiences and hack your way around until you get something to work. I have done this with other programs that didn't want to load. I just go to the folders and install directly from them and I have had great results that way. One nice way to get old software to work I found out.
Yours truly,
RGPruettJr
goto the site that is posted on here softsci....click the download for ur cam dont not open save the file to ur desk top after u save right click goto properties then click compatable i tried just about all of them but i got it to work i was surprized cuse i tried everything but i think i use windows NT 4.0 if that dont work just keep tryin different ones hope it works and u can understand wat i'm tryin to say computers are not my strong point but i got mine workin oh yea YOU MUST HAVE THE VEO SOFTWARE ON YOUR COMPUTER run that compatable with windows xp
I am trying to get my Veo Stingray Web cam to work with Windows Vista but I need to find the...
(More)
I am trying to get my Veo Stingray Web cam to work with Windows Vista but I need to find the software and driver compatible with Windows Vista. I had been using it with windows xp. home edition.
i have a veo stingray 330v 1.1 usb webcam and i need drivers can you help me i installed driver amx...
(More)
i have a veo stingray 330v 1.1 usb webcam and i need drivers can you help me i installed driver amx and they dont have them either
my cd comes up with errors so where on line can i download all the files i need for veo stingray...
(More)
my cd comes up with errors so where on line can i download all the files i need for veo stingray v001
I have tried to run the software to install this cam on my computer but it says it is not compatible b/c it only goes to like xp and I have vista. My computer ran a program to try to fix it and they couldn't find anything either. I would really like to use my cam without having to buy a new one.
