Question about Porter Cable Cable No. FC350A Clipped Head Framer
Plastic clips for clutch on skoda octavia 1800,turbo clutch,pedal reg number SK02 YNA
Can any,one help point me in right directon??? as ive got autistic son, and have to put him on bus PLEASE N THANKS John.
2003 skoda octavia 19 tdi turn on ignition key just clicks do this 2 or 3 times then it will start this has only happened since ive had the clutch and flywheel changed
Hi
Sounds to me like you've got a faulty solenoid on your starter motor which could have been damaged whilst the gearbox was taken off to do the clutch and flywheel or the wiring to the starter motor or battery hasn't been tightened up enough
Hope this helps Nick
Aug 27, 2017 | Skoda Cars & Trucks
My 2008 skoda octavia tdi keeps blowing fan resistors, why?
are the connections tight and not showing burnt or melting plastic perhaps the blower motor is defective causing the resistors to go
4 is a bypass so you will have blower but on lower settings the motor is probably causing a high resistance.
Jan 21, 2015 | Skoda Cars & Trucks
What are Fault codes P0441 + P0704 On my 05 Plate Octavia VRS?
Code P0441 seems to relate to the EVAP Emission Control System. Either there is a blockage or a leak in one of the valves (N80 or N115) or the pipes between throttle body and tank breather are broken.
Code P0704 seems to be a faulty clutch pedal position switch
Here's more info about code P0441 at ross-tech:
16825 P0441 001089
And code P0704 at ross-tech:
http://wiki.ross-tech.com/wiki/index.php/17088/P0704
Aug 27, 2014 | 2005 Skoda Octavia 1.9
Where di i refill 2008 Skoda octavia 6 speed automatic transmission fluid
trans.under or side (black color ) cove , remove all cover to drain the big plug for refill (plastic red color ) the small plug for level of trans. ATF.
Jun 15, 2014 | 2008 Skoda Octavia 1.4
Skoda octavia problems
check wheel alignment. check tyres for side wall bulges and belt separation. Check all suspension points for loose broken parts . Check for loose steering joints.
Mar 23, 2014 | 2010 Skoda Octavia 1.6
Location of oil filter in Skoda Octavia 2006 1.9 diesel
Octavia (a4 ) remove top engine cover the engine oil filter is at front cover, big black plastic cover remove with special tool the oil filter can be remove and replace with plastic ring
Nov 21, 2013 | 2006 Skoda Octavia 1.9
How do i remove front grille frame from skoda octavia
I have no idea how to remove the front grille of Octavia but to solve out your problem I found out one video which is showing to replace the new front grille with old or damage one. May this video helps you. Have a look
Apr 13, 2013 | Skoda Octavia Cars & Trucks
How to remove the air from the clatch system of skoda octavia estate 1.6 2005
most of the clutch hidraulic systems do not have purge valbe for air when I have that problem i follow the same steps of the brakes system and when the fluid is presurised I losse the bottom endon the clutch cylinder a few time untill no bubbles come out and that work for me very good.
Sep 01, 2012 | 2005 Skoda Octavia 1.6
Slipping clutch?
it sounds like thr clutch has burnt out does it smell when you are drivind if so you need a new clutch , pressure plate & through out bearing good luck
Mar 15, 2009 | 2004 Volkswagen Passat
Porter Cable Cable No. FC350A Clipped Head Framer Logo
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
