Question about Sharp AL-1641CS All-In-One Laser Printer
Sharp 1641cs - Dark/black page after replacing drum & toner
The unit was on its 3rd to 4th toner cartrige when the drum replacement light came on and stopped copy/print. We replaced with OEM drum & toner but it produced only a complete black page which was surprising as there had been no copy/print issues prior. The unit was taken out of service and stored for the last two years but I would like to put this back in service as backup printer. Any suggestions would be appreciated.
  • C Braznell
    C Braznell Jan 14, 2013
    It is fairly clean, would this be a defective toner or drum cartridge?
  • C Braznell
    C Braznell Jan 26, 2013
    Cleaned the charger and blew the unit out thoroughly and cleaned the corona wire, still the same results. Tried putting back in the old drum cartridge and still a full dark page. Any other solutions?
  • Sharp Expert
  • 257 Answers
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Posted on Jan 16, 2013
  • Anthony Karuku Jan 31, 2013
    Wipe clean the laser unit ie the one inside the copier where the drum enters. Also wipe the glass mirrors on document cover and the ccd unit. Something is obstructing there.
  • 883 Answers
SOURCE: Consistent Squeaking Noise
The fuser unit, [near the paper exit] which heat-sets [fuses] the toner onto the paper, has bearings (bushings) that are screaming for high-temperature grease. Open it, and apply some common sewing machine oil onto the bushings. If the noise stops, you will need to repeat this every 2-3 months or disassemble the fuser roller and apply high-temperature grease.
Posted on Jun 24, 2007
  • 2072 Answers
SOURCE: Sharp AL-1641CS printer/copier
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
Posted on Jan 11, 2008
  • 67 Answers
SOURCE: Sharp AR BC320 not printing correct colors
First of all, this copier doen't have print heads that spray ink like an inkjet. Its print heads (4, one for each color) are LED arrays, all they do is emit light. They can get dirty, but not clogged with ink.
Suggestion: Make a color copy at the copier, then print a color picture from a workstation. If the copied page looks good and the printed one doesn't, the copier is probably OK. Reinstall the print driver. I suggest you download the latest driver just for effect.
This worked for me at a customers site just today.
Posted on Feb 28, 2008
Bubbabear64
  • 2794 Answers
SOURCE: black lines running vertically through resulting copies
Clean the scanner glass. a small particle will cause this to happen.
Posted on Jun 06, 2008
  • 214 Answers
SOURCE: Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Posted on Apr 23, 2009
New toner and new drum and paper come complete dark
Hi there, it seems that the paper was coming out black not because of drum or toner .Replace the drum cleaner blade and developer as well. If it comes black again, check the charge unit and replace it then clean the optical parts that is the document glass and the small mirrors.
Jan 20, 2011 | Sharp AL-1641CS Laser Digital Copier
I recently changed my copiers toner (the change toner light came on) and now my copies are uneven (alternating in light and dark patterns). I properly shook the toner, I even returned the toner to get a...
The light and dark banding going horizontally accross the page is usually caused by the drum unit. This is the smaller of the 2 cartridges and it sits just to the right of where the toner sits. If you have a spare drum unit, replace it. This should resolve the problem. The Toner cartridge can also caus this but if you have tried 2 DIFFERENT units with the same banding then it must not be the toner.
Good Luck and Thank You for using Fixya.
Jun 15, 2010 | Sharp AL-1642CS Copier
The unit is not printing dark black anymore it is a light gray print out.
The problem is either in the toner cartrige or in the drum unit. Check both items or may be all in one cartridge. Try replacing.
Dec 30, 2009 | Star Manufacturing International STAR...
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
AR -208 N Needs starter and drum replaced. Need
For given repair will take:
Fotobaraban AR-202DM.
Pliers
The Vacuum cleaner for peelings of the node removable unit containing and corona.
To take the block of the drum out of copier it is necessary,disconnect feeding,open shift to the right lid,on she is found corona carrying,open the front lid,take out the toner-cartrige,take out the block with developer and finally take out block itself with drum.
The Bonanza block before itself.With pliers we roll the dowel,which keeps the drum and take out him(it).
We Remove drum.
The Vacuum cleaner net corona and removable unit containing .
We Put new фотобарабан,insert and twist the dowel.
We Insert the block of the drum on place,then block with developer and toner-cartrige.We Close shift to the right door,include the device.
May 09, 2009 | Sharp Office Equipment & Supplies
My Sharp AL-1641cs won't print. Just keeps flashing red drum.
SOUNDS LIKE YOU NEED TO REPLACE THE TONER CARTRIDGE, THEY GO THRU LONGER WARM-UP PERIODS WHEN THE TONER GETS LOW AND IF YOU LET IT RUN YOU WILL SEE RED LIGHTS LIKE STACKED CANNON BALLS, WHICH MEANS ITS OUT OF TONER
Feb 18, 2009 | Sharp AL-1641CS Laser Digital Copier
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
All of my copies have toner on the right edge. How do I fix this?
If it keeps coming back on the drum then replace drum.
Very unlikely that the toner is bad.
Oct 14, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1641CS All-In-One Laser Printer Logo
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
