Question about QuarkXPress 7 Full Single User Mac/Win Upgrade Version for PC, Mac
I can't get Quark Xpress 9 to launch
Every time I got to start the program, it gives me this: Description: Stopped working Problem signature: Problem Event Name: CLR20r3 Problem Signature 01: quarkxpress.exe Problem Signature 02: 9.1.0.0 Problem Signature 03: 4e56c151 Problem Signature 04: PresentationCore Problem Signature 05: 3.0.0.0 Problem Signature 06: 4ca2e2dd Problem Signature 07: 5021 Problem Signature 08: 0 Problem Signature 09: System.TypeInitialization OS Version: 6.1.7601.2.1.0.768.3 Locale ID: 1033 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
  • 114 Answers
Go to: C:\ProgramData\quark and delete all sub folders and files present there.
If that doesn't makes any difference in your case than you can run System File Checker (sfc).
You may try uninstalling Quark, rebooting the computer and re-install it.
If at all you don't get any help with that as well than you can try performing system restore.
Posted on Jan 15, 2013
4 Suggested Answers
rajak2009
  • 527 Answers
SOURCE: QuarkXpress 7.0 clips picture "at back" when printing
Sir,
Check these 2 links
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Apr 21, 2009
  • 108 Answers
SOURCE: Want to convert Quark 7.3 file to Quark 4.1 so it
Thats not possible.
QuarkXPress 7 would allow you to downsave to a QuarkXPress 6 document but not to QuarkXPress 4.
you would have to open the document in QuarkXPress 6 then save to version 5, then open the same in QuarkXPress 5 and then downsave to 4
Posted on Jan 13, 2010
Testimonial: "Helpful but long winded solution I heard of already. I was hoping something better was out now as I dont have all those versions of Quark to back-save"
SOURCE: quark xpress no longer valid error
iI,m also angry, coz i've lost my Cd Key of Resident Evil 4. I want to play But I can't. Plz Tell Me that how can i get back my CD KEY again?
Posted on Feb 24, 2010
Running Mac OS X (Snow Leopard)....Quark 7 will not launch due to damaged application preference....says to delete file and relaunch....that does not work... Also....when Quark was working on OS X (Snow...
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then deleted the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps.
Sep 13, 2011 | Computers & Internet
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
The application preferences file is damaged. Please remove it and re-launch QuarkExpress [297] Where is the preferences file located? (Version 9, Windows 7)
The preferences file will be in the User\AppData folder.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 7 is the location in Vista with version 7 and it should have a similar location in Windows 7.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 9 is likely. (AppData has 3 folders - Local, Local Low and Roaming.)
You should not delete the folder. Instead rename it. Right click on the folder and select Rename. Then name it
old_QuarkXPress 9.
This could be a hidden file. If you click Start and then enter Show hidden folders. Then put the bullet on Show hidden files, folders and drives. Then click Apply and OK.
If moving the AppData location to another folder doesn't solve the problem, check if there is a Preferences file in the Program Files folder (
C:\ Program Files\ Quark\ QuarkXPress 7.x for the old version.) If the new version is built for the 64-bit OS, it might be in the x64 Program File folder. Again rename the file if it is in that directory.
I hope this helps.
May 14, 2011 | Computers & Internet
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
After using my quarkxpress 7.1 everyday for 5 years, this morning it won't launch. I just get the logo screen with whirling color disk. Can you help me resolve this?
It sounds like your preferences file has corrupted.
This solution is for Quark on a Mac. What you could do is go to users then which ever user is the active one then library then preferences then quark then QuarkXPress 7.0 in this folder is a file called "XPress Preferences.prf" move it to the trash and then start up Quark, it should rebuild the file. (Do not empty the trash if it does not work you can replace the file back into the preference folder)
Please note your preferences will be back to default and you will need to reset them.
Hope this helps.
Mar 25, 2010 | QuarkXPress
Quarkxpress 8 quits during launch. Macbook pro OS X 10.5.6
Mar 08, 2010 | Apple Computers & Internet
Quark won't open. I have shut down, completed repair permissions . . . no luck. Starts to load and immediately quits. This started after doing an update on Microsoft Office. What can I do? I am using Quark...
This is for Quark on a Mac. What you could do is go to users then which ever user is the active one then library then preferences then quark then QuarkXPress 6.0 (or may say 6.5) in this folder is a file called "XPress Preferences.prf" move it to the trash (Do not empty the trash if it does not work you can replace the file back into the preference folder) and then start up Quark, it should rebuild the file.
Hope this helps.
Nov 11, 2009 | QuarkXPress
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
Corrupt documents
please try to open the document on a diff machine and if it doesnt works then contact quark tech support for assistance
Jan 15, 2008 | Quark AVENUE XPRESS (115261) for Mac, PC
QuarkXPress 7 Full Single User Mac/Win Upgrade Version for PC, Mac  Logo
142 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Michael Galve
Michael Galve
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
