Question about Reebok Exercise & Fitness
Treadmill stops running after 10 mins,won't start for about an hour
    Top Expert:
  • Reebok Master
  • 12,223 Answers
LUBE the deck belt +rollers bearing. This happen because lack of lube and maintenance according with the s. maintenance
see the video
God bless you
Posted on Jan 11, 2013
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
  • 43 Answers
SOURCE: healthrider s5001 treadmill stops during workout
check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
Posted on Jan 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: i have a model T-10 endurance treadmill when it
Unplug unit and remove motor shroud ,check upper & lower wire for solid connections , check condition of magnet on front roller to see if missing or still in place if not replace the roller. Next to the front roller, their is a speed sensor ( reed switch ) unplug the leads going to the the lower board use a multi meter to check continuity of the switch by inserting the leads into the connector and manually rotating the front roller back and forth opening and closing the reed switch if not operating properly then replace the switch.
If the above procedure did not resolve problem and still ERROR 1 then check the Motor Control Board LEDs 6 & 7 If LED 6 isn't on, change a new upper console if on then motor control board needs to be replaced if LED 7 is not on ( that a mouth full )
If LED 7 on - current overload circuit meaning too much friction between belt and deck you will need to apply good quality silicon lubricant that may be purchase @ gympart.com part# TM001
If then if the overload problem, still exists and lubrication did not the help then the belt and deck are worn and need to be replaced. Very seldom do we need to replace the Drive Motor problem is around 8% failure rate. You will get plenty warning if the motor goes out.
Posted on May 18, 2010
  • 15 Answers
SOURCE: I have a reebok fusion treadmill, been fine until
reset the running timer, for the amount of time you would like to walk run ecsetra
Posted on Oct 25, 2010
georgiejm201
  • 54 Answers
SOURCE: my treadmill runs for 15 minutes than stops for a
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Posted on Jan 12, 2011
Headache
You might need a new starter what's happening is when the starter heats up it won't start up again until it cools off
May 30, 2013 | Vehicle Parts & Accessories
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
2003 Chrysler 300 intermittent starting problem
Cam Position Sensor could be your problem.
Mar 22, 2012 | 2003 Chrysler 300M
Saturn starting promblem.
Had same problem with 6cyl. merc.
Started fine cold but wouldn't start when turned off hot.
Replaced spark plugs & worn dist. cap .Problem solved.
Feb 23, 2012 | Cars & Trucks
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
Healthrider s5001 treadmill stops during workout, shuts down. Will run for appx. 10 min.
Jan 08, 2010 | Quantum ® 3.3ESD Treadmill
Reebok i run treadmill stops working after 10 mins
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Bowflex series 3 stops after 10 min
To much electrical draw on motor control board
Lubricate, lubricate, lubricate
Jan 26, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
778 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
