Question about Bower SFD926 TTL Flash for Nikon
Over exposure In TTL mode picture are overexposed
    Problem Solver:
  • 5 Answers
I have the same problem. I've found using the diffuser or bouncing the flash helps.
Posted on Jan 27, 2013
  •  Steve Shaffer
    Steve Shaffer Jan 27, 2013
    IN reseraching this I came across this very good discussion on issues with NIkon DLSR settings http://www.flickr.com/groups/nikondigita...
My MK2 will not change the iso when in video mode
Have you tried to put the exposure mode to "manual"? If you leave it in automatic exposure mode, the iso, speed and aperture will always combine themselves to give the correct exposure and therefore will not let you overexpose your video. Hope this will help.
Dec 22, 2013 | Canon EOS 5D Mark II Digital Camera
I need to know how to read my light meter when taking pictures on the manual mode.
In short, if the lights to the left are lit then you're overexposing and you need to reduce the exposure. If the lights to the right are lit then you're underexposing and need to increase the exposure.
Full details are in the "Manual Exposure Mode' section of the manual. If you need a manual, you can download a copy from
http://butkus.org/chinon/nikon/nikon_n55/nikon_n55.htm
Sep 04, 2011 | Nikon N55 35mm SLR Camera
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Shooting with a Nikon zoom such as 18-200 with a Nikon SB800 flash on a Nikon D300 body. I make an exposure of a person and the result is exceptable and then I zoom to the whole group of five people and it...
Depends on the zoom length. If you check exposure at zoom 18 mm then zoom to (lets say) 100 for the final picture the flash will zoom concentrating the flash power as well; the flash gets stronger. This is all explained in the SB-800 manual. On a zoom such as the 18-200 the more you zoom the smaller the f/stop. You are better off with a zoom that maintains its f/stop through the entire zoom range. That way when you check exposure at 18 mm lets say f/2.8 then zoom in it will maintain the same f/stop. Myself I am not a big fan of zooms especially ones when zoomed change to a smaller f/stop.
Aug 05, 2010 | Nikon Speedlight SB-800 TTL Flash
Pictures white out; pictures are completely overexposed; I've had this problem with Casio cameras before; The video capacity works fine, it just can't take any clear pictures. All pictures come out...
Check the exposure compensation setting:
  • In REC mode, press MENU
  • Select the "Quality" tab and select "EV-Shift"
  • Set the exposure compensation value to zero.
If this doesn't help, please post a sample picture (e.g. upload an unedited full size image to http://imageshack.us/ and post the link as a comment).
Mar 29, 2010 | Casio Exilim EX-S600 Digital Camera
Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
Jan 21, 2009 | Bronica ETR-Si Medium Format Camera
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
Aug 31, 2008 | Nikon D40x Digital Camera
Inconsistent exposure. even if i change my settings. but this is only sometimes. i can shoot twenty shots and they may all be perfect. but then for no apparent reason the exposure is either over or under...
There are dozens of causes of inconsistent exposure with automatic flash systems. More common ones are inadequate recycling time (shooting before the ready light comes on), weak batteries that lengthen the recycling time or an intermittent anomaly in the internal circuitry of the unit which can only be traced by a qualified technician.
If the unit is used in auto mode (not TTL) dirt or ones hand can block the photo-electric sensor on the unit and affect exposure accuracy.
One other cause of inaccurate exposure is something called “subject failure”. This can occur in a large room like a church, ballroom, gym or a large rotunda. What happens is the automatic system in the flash or the TTL system in the camera reads the entire room and not a smaller subject in the image. Think of a bride and groom dancing in a large hall, the system would read all the space and possible darkness surrounding the subject and overexpose the subject. This often happens with automatic flash equipment that was originally designed for film cameras. On DSLRs, the sensor in the camera may react differently in terms of the area that it is reading. Some of the newer flash units are more compatible with digital equipment.
If you are missing only 1 shot out of 20- that’s not too bad considering all the variables.
I hope this helps!
PS- If there are problems in the circuitry, unless you are an experienced technician with high voltage devices, it is not advisable to try and service the unit at home. Many flash units harbor lethal voltages that can cause burns, nerve damage, serious electrical shock or even death. Theses voltages can remain in the unit even after it is turned off.
Ed
May 22, 2008 | Metz 70 MZ-5 TTL Flash
Overexposed pictures and white horizontal lines
I also having this problem white horizontal lines ...any solution?
If repair how much around?Please help!
Aug 12, 2007 | Canon PowerShot SD20 / IXUS i5 Digital...
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Bower SFD926 TTL Flash for Nikon Logo
Top Bower Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Bower Camera Expert? Answer questions, earn points and help others
