Question about Philips Cameras
I have Philips CCD observation camera VCM 8120/00T. The quesion is how can i connect it to TV to get the picture on it?
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
Records sound but no picture
When you hook the cam up to a tv for playback, does it have video?
Jul 25, 2008 | Sony Handycam CCD-TRV37 Camcorder
My phillips SPZ3000 cam is very dark at nite with the light on
Change to another camera. The problem is in your cameras ccd chip. The sensibility of that chip in your camera is not strange enough to sens the light and create the picture.
I hope you have a normal light source not a night lamp or a torch or so...
Dec 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
My powershot A75 is only displaying fuzz like a bad tv reception when in picture taking mode, display works fine in playback. any idea how to fix this?
This is known problem of ccd imager failure in Canon A75 camera and ccd imager will be replaced to get correct live view to take fresh pictures.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Thanks.
Apr 08, 2010 | Canon PowerShot A75 Digital Camera
When recording, no picture thru viewfinder or lcd panel. Records sound. Was working fine, just started this, and the lens cap is off. Any assistance greatly appreciated.
It could be either aperture is stuck or ccd imager chip is defective in your camcorder that will be replaced.
In bright light, look into camera lens, turn ON in camera mode and observe does aperture open like an eye?
If you notice some thing opens right in center of camcorder lens then aperture is working and ccd imager chip is bad that will be replaced.
Let me know model number of your Sony camcorder to provide you ccd imager part number info.
Thanks.
Dec 09, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Need to reset my powershot a85
Its problem of bad ccd imager in your camera and ccd imager will be replaced.
Canon will repair Free of Cost for bad ccd imager as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A85 Digital Camera
TV shuts off after about 30 minutes and have to unplug and reset
Go to the Philips website and see if they have the problem listed; if they do, they probably can identify the solution. If not, the website should have a link to answer quesions.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Horizontal Lines throughout the images
My friend, I believe that that is a CCD issue. The horizonal lines and the interrmitent issues with the images are all related to a CCD issue that was notorious on the S-series camera.
Why the tech told you there is no CCD is beyond me, but all cameras either have a CCD or a form of the CCD and this is most likely causing you the issue.
eBay is a very good spot to find replacement parts!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Cameras Logo
309 people viewed this question
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Mohamed Ismail
Mohamed Ismail
Prashant Hattangadi
Level 1 Expert
Are you a Philips Camera Expert? Answer questions, earn points and help others
