Question about Toshiba E-studio 3510c Copier-scanner - Fax & Network Printer
Error code c390 - Toshiba E-studio 3510c Copier-scanner - Fax & Network Printer
Dx-c390 gives mmech error. How to fix?
What does the manual say about this error?
Feb 01, 2018 | Audio Players & Recorders
E-Studio 2820c. How do I correct error code C390?
On the black process unit, there is one sensor contact with the drum surface, make sure there is no stain on the sensor or the drum surface...
Jul 31, 2015 | Toshiba Office Equipment & Supplies
C390
[C390] Auto-toner sensor-C abnormality (Cyan)
<Color toner low density>
When you check the printing status to find out that the color printing ratio isless than 5%, color toner low density might be the cause.
Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged number of sheets setting".
If the color printing ratio is 5% or more, check the following.
(1) Is the developer unit installed properly?
(2) Check if the connector CN340 on the LGC board isdisconnected from the auto toner sensor or the harnesses are open circuited. Correct if necessary.
(3) Check if there is any foreign matter such as toner in the drawer connector of the equipment and fuser unit or the connector of the auto toner sensor. Remove if there is and reconnect it.
(4) Service or replace the auto-toner sensor.
Apr 04, 2014 | Toshiba E Studio 2330C
Remote Control Code Question
Codes to check with Onkyo brand are; 0284,0288,0281,0228. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 06, 2013 | Yamaha Remote Control RAV285 p/n:WN058300
The display will not light up
When CD exchanger is turned on, it states searching for disc,
then defaults to an error message. Door also not opening all they way since this problem started.
Jul 28, 2013 | Onkyo DX-C390 6-Disc CD Changer
I cant link my bluetooth HS805 with my motorola c390. It is asking for a pin and i cant remember
pin is the one which will be printed on the screen of the pc,please type that pin in your mobile and click ok
Oct 05, 2010 | Motorola Mobility C390 Cellular Phone
I can't turn on the unit.
no on/off switch on this model; use the remote or load it and press play AFTER you plug it in............
Jun 06, 2009 | Onkyo DX-C390 6-Disc CD Changer
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
Toshiba E-studio 3510c Copier-scanner - Fax & Network Printer Logo
22 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
