Question about Bradford White M280R6DS2 80 gallon 240v Electric water heater
Need to keep resetting the hi limit
Runs for an hour or so and then needs to be reset
  • Bradford White Master
  • 5,245 Answers
Reset button on a o smith keeps tripping
After the high limit trips once, it is no longer calibrated. Replace the upper stat and limit.
Mar 21, 2017 | Water Heaters
Why does the reset button on one of the tanks keep kicking when no water is being used?
The tank is overheating when not in use. If it is an electric water heater, you must replace the upper and lower thermostats as well as the high limit(reset button). If the tank is 10 years old or more, you may want to replace it rather than fix it as the average life of a tank is about 10 years before it starts leaking.
Mar 03, 2016 | Water Water Heaters
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Aug 23, 2012 | Water Heaters
Getting A2 code and hot water shuts off. We do a reset and hot water will run for awhile then we get A2 code and no hot water again.
Thanks for stopping by:
A2 error on your Bosch water heater means "Fault in the flue gas limiter"
This can be caused by several things:
The gasket on the flue gas collector may be dislodged/leaking.
Check/Remove/Reseat the gasket.
It will not reset until about a two hour cool down.
Also - check the overheat sensor fuse wire - it may have gotten hot and melted the jacket and/or been dis-colored.
Finally - there is a retrofit kit "repair" that can be obtained by calling them directly.
1-800-642-3111 and request the "FLUE GAS LIMITER RETROFIT", Part NO. 8-700-400-032. This should solve many error code situations and get you on your way again.
Thanks for using FixYa!!
Aug 03, 2011 | Bosch & Tankless LP Hot Water Heater
Reset button needs reset daily
Thermostat may need replacing in order to take care of this issue.
You may try turning temperature down a little and see if it will stay on. Temperature may be set high and heater heating beyond limit and tripping it out.
More than likely theremostat is going bad.
May 28, 2010 | RELIANCE ELECTRIC WATER HEATER
You need to press the reset butten every 10 hours
If you have to keep resetting it the thermostat maybe going bad. They are not to costly maybe around $15 dollars.
Inspect the element's wiring and make sure that it look's intact and no burnt look to it. They can short out and trip the reset button also.
Turn power off and disconnect the thermostat one wire at a time and reconnect to new one. You could draw yourself a diagram of th ewiring pattern to make sure you wire it back up correctly.
May 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
York Dianond 80 Furnace
You have a limit switch that needs to be reset. It is probably the roll out switch that is located on the burner housing. The limit switch is a disk about the size of a dime or penny and has two wires to it. There is a small button in the middle of these two wires. Press this button firmly to reset it. Look for all the limits that may be on the unit that is manual reset like the one described above and do the same. This should correct your problem.
Apr 12, 2009 | Water Heaters
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
Bradford White M280R6DS2 80 gallon 240v Electric water heater Logo
295 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
