Question about NorthPoint Indoor Outdoor Wireless Weather Station
I have a Northpoint indoor/outdoor wireless weather station GM8047. Worked fine for awhile, batteries ran out and it was a few months before I installed new batteries. Now the outside unit works fin
Debra
Out do I get the outside temp back.
You have to remove all batteries, both outdoor and indoor. Install replacement batteries in the outdoor unit. Back indoors, install replacement batteries in the indoor unit and wait for temperature to be displayed. If nothing happens, the outdoor unit may have failed.
Jun 17, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
How do I set the time and date on my Thermor thermometer
Hold down the mode button for a few seconds > display starts to flash year > use +/- buttons to set year > press mode to present the month/day/time etc, again using +/- buttons
Nov 24, 2014 | Thermor Indoor/Outdoor Wireless Thermo
How do I get the -- away and get the outdoor temperature to work?
You may have to "reset" it by removing both indoor and outdoor unit batteries, waiting briefly, then reinstalling batteries in the outdoor unit followed by the indoor unit. After awhile, the outdoor unit should begin sending information to the indoor unit.
Nov 20, 2014 | Oregon Scientific Wireless Weather Station...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
Is there an online manual for Springfield 91756 Wireless Thermometer w/Indoor/Outdoor Temperature & Humidity
Yes. Took awhile to find it, but here is the link: https://docs.google.com/gview?url=http://www.weatherconnection.com/manuals/91756.pdf&chrome=true
Aug 07, 2012 | Springfield Measuring Tools & Sensors
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Sep 28, 2010 | Taylor 1528 Wireless Digital Indoor...
NorthPoint Indoor Outdoor Wireless Weather Station Logo
Top NorthPoint Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a NorthPoint Measuring Tool and Sensor Expert? Answer questions, earn points and help others
