Question about Drills
Drilling out screwheads, not screwing the screw in!
Recently bought this, have charged it and started to put together a bookcase. First two screws brilliant, the next two the screws don't move at all and all I seem to have done is drilled out the top of the screw. This is the first power tool I've ever used so it's probably operator error but I have no idea what that error is! Can anyone help. Bookcase is soft pine so I'm not trying to go through hardwood and yes, the screws were lined up properly.
    Sergeant:
  • 170 Answers
Sears has a great easyout bit setup. They work great for getting stripped screws out.
Posted on Jun 01, 2017
4 Suggested Answers
  • 398 Answers
SOURCE: when in drill mode the tork still kicks in on my dewalt
there is a gear and a clutch as agier said in the head. if its old it looses its catch, youll need to take it apart and look at it. the torque setting just tightens on the head the more you tighten it the less it will give( the ratcheting you hear when you set it low) .expensive drill so its worth trying to fix. how old is it? as for drilling thru knots and hard wood make sure your bits are sharp, you can spend alot of time trying to drill with a dull bit. do you sharpen your bits? i do alot of drilling with battery drill thruout the year and believe me a sharp bit is waaaay easier. though ive never had to sharpen concrete bit because they always break when they get old and i buy new.
so your saying it stops completley when you hit something hard, right. does it ratchet?
Posted on Apr 23, 2009
  • 14 Answers
SOURCE: Power drill drills batons screws half way then
if this is a corded drill it is not really designed to scewdrive you may need to get get diff tool
Posted on Nov 13, 2009
dwalters5
  • 12 Answers
SOURCE: charged battery put in drill tried to screw i
their triggers have a problem and they have a recall on almost all them i got a new one because the trigger s burn a hole though call the 1800
Posted on Nov 03, 2012
Holes missing from 5 tier bookcase metal Putting shelves together. Can I drill Holes in metal?
Yes you can, you just need a drill, the correct size SHARP drill bit, a pin punch - important!! - (to punch a dent in the exact place you want the hole to be - this will hold the drill bit in place when you start drilling)..take you time..use a piece of wood (2x4) to back up the piece your are drilling into... then deburr with a file..
Jul 02, 2017 | Drills
I need help disassembling an Ashley Zayley full size bed. There are 4 sets of screws that are holding the bed together but none of them will unscrew.
Screws in beds are designed to be quite tight, so that there's no movement, which would be quite aggravating to the person lying on it. Likely the constant movement has seated the screws even more firmly. I can only suggest better tools, or drilling them out.
Jun 16, 2017 | Baby Gear
Need the instruction to put my bookcase together
Were there no instructions in the packing? If not call the shop or go down there and open another box. A good DIYer should be able to work it out. There's normally a step by step instruction sheet inside.
Jan 05, 2015 | Mainstays 3-Shelf Bookcase Black
No instruction came with my 3 shelf bookcase how do i assembl it
I see from the Walmart feedback on this item that there is a problem with missing instructions so further to my other answer posted I suggest you go to Walmart, find some instructions in another box and demand they copy them for you or take the item back and check the box before taking a replacement.
Jan 05, 2015 | Mainstays 3 Shelf Bookcase-Alder
Won't turn on - even after orienting the magnets
firstly u shouldn't have taken the thing apart DDDUUUHHHH
Jan 06, 2014 | KitchenAid KSM150PS Artisan Series Stand...
How do I take a stripped torx screw out of my throttle body!
Hi, The best way to remove it is to use a screw extraction tool.
Which works by you drilling a small hole in the top of the screw and then screw in the extractor which as you wind it in will start to turn the screw out.
Hope this helps.
Thanks
Jason
Jul 28, 2011 | 1995 Dodge Intrepid
Bought the 4 shelf shower spring loaded shower caddy need instructions please
The first thing you can do is to drill the exact hole for the tox.After drilling,put the tox to the hole and hang the shower caddy and then you can put the screw.
Jul 17, 2011 | Home
I cannot remove screws from wood the drill just just turns on the phillips screw head
The screw is either broken ,the hole stripped out, or screw not into something solid.Try prying up under the screwhead with something as you turn it with the drill
Apr 19, 2011 | Dewalt DC720KA 12 18V Cordless DrillDriver...
I am having problems getting the screw to screw all the way into the E-Z ANCOR. The plastic E-Z ANCOR screwed in quite easily and is snug up against the dry wall, but the metal screw is not easily screwed...
There are many different models of these drywall anchors, some of which will not allow a too-long screw to be used. But the plastic ones shouldn't have this problem, because the tip (inside the wall) is supposed to split apart. However, you have to drive the screw a bit harder when you get to the point where the plastic starts to split. Do a google image search for---- ez anchor self drilling drywall ---- to see a few useful images.
Aug 09, 2010 | Midwest E-Z Ancor Self-Drilling Drywall...
Hi i recently bought a kaiser 125cc and it was working great for first few weeks. But now when i change to 2nd gear or above it stalls or loses revs(power). Also clutch is squeaking whilst driving. Is...
Install a new stock NGK spark plug and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and then install the carb. Before putting the slide back into the carb, move the clip on the jet needle one notch lower than where it is now. Let the float bowl fill then start the engine. This process should get you back on the road.
Apr 14, 2009 | Skyteam ST 125-3 Motorcycles
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
