Question about Samsung WF520ABP - 5.0 cu. ft. Steam Washer
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always happens with 11 mins. left on the cycle. There is no water or very little in the tub when it occurs. The fault is intermittent, about 1 out of every 4 washes. I have cleaned the hoses to the drain and the small hose which is used to drain the machine. Moving the drum is free and easy - not jamming. Any suggestions.
    Habit-Forming:
  • 145 Answers
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
Posted on May 16, 2017
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Error code se on samsung front loader 7kg
could the code be 5e if it is a 5e then the problem would be
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Another tech has also done a previous post to this subject so click here to see her repair as well http://www.fixya.com/support/t5093804-se_mean note that if this repair does not work please message me back and there will be other tests for you if this repair she lists does not work if you have any further questions also message me back with them and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 16, 2011 | Samsung WF337AA Front Load Washer
Describe your samsung wf-b 1061 error code 5E Problem
Error code 5E is the code telling you that you will need to clean the filter. After you clean the filter the code will go away.
Dec 19, 2010 | Samsung WF317AAG Front Load Washer / Dryer
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Ive got a samsung t1253 its shows error code 5e how do i fix it
5E - WATER DRAIN ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2010 | Samsung WF337AA Front Load Washer
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Jun 19, 2009 | Samsung Washing Machines
Samsung WF520ABP - 5.0 cu. ft. Steam Washer Logo
122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
