Question about Exercise & Fitness
Where can i find a replacement magnet for my nordictrack a2105 model
    Top Expert:
  • 12,223 Answers
You can two place
a) www.fitnesrepairparts.com
or
2) www.treadmilldoctor.com
GOD BLESS YOU
Posted on Jan 11, 2013
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: NordicTrack A2105 console is very faint to read
It sounds like the upper console has a loose connection ( check wire harness connections in the upper and lower board section ) or the upper console is failing call Icon Fitness @ 1-800-999-3756
Posted on Jun 14, 2010
My NordicTrack x9i will not recognize the magnetic safety key - it was working fine and now nothing? any ideas?
The magnetic read switch is faulty . You have to replace the reed switch.If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.com/
Nov 01, 2016 | NordicTrack Exercise & Fitness
I have a A2105. When I turn on the power it starts by it shelf runs on 1 and when I run on a higher speed after a while it goes back to 1
this is a problem with Console Control with CPU, you must replace.
However you must sure if the signal coming out from the control motor to the upper board are o.k Otherwise time to replace the control board since, they send the signa from the inverter to CPU.
Feb 11, 2015 | Nordic Track Nordictrack A2105 Treadmill...
Will not turn on. flashing blue light
If the console only reads zeros or the controls do not function properly, try adjusting the reed switch. You will need a Phillips screwdriver to remove the motor hood and adjust the reed switch. Unplug the power cord, remove the motor hood and locate the reed switch, which is on the left side of the belt pulley. Rotate the pulley until a small magnet comes into view next to the reed switch. Loosen, but do not remove, the screw on the switch and move the switch with your hand until the gap between the switch and the magnet is 1/8 inch. Tighten the screw and replace the motor hood. The Controls Are Not Working on NordicTrack Treadmill LIVESTRONG COM
Feb 09, 2015 | Nordic Track Nordictrack C2500 Treadmill...
I have nordictrack A2105 and although we "oiled" the belt and replaced motor belt, it still slips. What are we doing wrong?
remove the hood. Turn the treadmill on to speed of 4 or 5 and straddle the walk belt. While the treadmill is running (with good shoes on) step hard on the walkbelt while observing the motor belt and front roller belt pulley. Does just the belt or front roller stop? if so the belt is loose. If the belt does not stop check to see if the front roller stops and the front roller pulley keeps going. If so the front roller pulley is slipping on the roller. If the belt, pulley and front roller are all moving and the walkbelt is the only thing that stops when stepped on then the walk belt is loose. To repair a slipping front roller you have 2 options: 1) purchase a new roller assy or 2) loosen the motor belt and push it to off to the side of the front roller pulley (no needto remove). Realign the roller pulley to the motor pulley. You may have to tap it into alignment. On the inside section of the grooved part of the pulley drill an 1/8" hole thru the pulley and thru the roller housing. (If you drill to the outside portion of the pulley on the left hand side you will hit the roller bearing. Now take a larger drill bit like a 3/8" and lightly countersink the plastic pulley - try not to drill thru the pulley with the larger bit. Using a thin head sheetmetal screw, install the screw so the head is just below the ribbed surface of pulley. If you screw up your first attempt just rotate everything 90° and try again.
Nov 11, 2014 | Nordic Track Nordictrack A2105 Treadmill...
NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
Jun 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
My nordic track A2105 treadmill won't start. What's wrong? When I plugged it in and flipped the switch, the console lit up for about a minute (if that long) then went out. I had an accident last year and...
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter plug the unit in and start checking the AC all the way to the lower board and see where the AC is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Nordic Track NordicTrack Treadmill, A2550
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Mar 01, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
