Question about NordicTrack E4000 Treadmill
Lost magnet for the nordictrack a2105 model
Where can i buy a magnetT THAT WILL WORK ON MY NORDICTRACK A2105 MODEL
    Top Expert:
  • NordicTrack Master
  • 12,223 Answers
Go to the next places
1) www.fitnessrepairparts.com
2) www.treadmilldoctor.com
God bless you
Posted on Jan 11, 2013
My NordicTrack x9i will not recognize the magnetic safety key - it was working fine and now nothing? any ideas?
The magnetic read switch is faulty . You have to replace the reed switch.If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.com/
Nov 01, 2016 | NordicTrack Exercise & Fitness
I have a A2105. When I turn on the power it starts by it shelf runs on 1 and when I run on a higher speed after a while it goes back to 1
this is a problem with Console Control with CPU, you must replace.
However you must sure if the signal coming out from the control motor to the upper board are o.k Otherwise time to replace the control board since, they send the signa from the inverter to CPU.
Feb 11, 2015 | Nordic Track Nordictrack A2105 Treadmill...
NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Jun 10, 2012 | Exercise & Fitness
I have a Nordicktrack A2105. When I turn it on the belt runs real fast like a second then stops everything on the panel is working as if the belt is still working but its not. Can there be something...
there is an optic sensor on the top roller that drives the belt. if it has fell off the computer can not sense the rotation. you may have to remove the cover where the motor and top roller is and inspect that the sensor is in place and no dirt is obstructin the signal. good luck to you.
Feb 07, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack A2105 console is very faint to read
It sounds like the upper console has a loose connection ( check wire harness connections in the upper and lower board section ) or the upper console is failing call Icon Fitness @ 1-800-999-3756
Jun 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
I lost my magnetic key and other magnets wont work
Go to IconFitness.com go to customer service order part # MAGNET 195476 NETL198070 $2.22
May 09, 2010 | NordicTrack E4000 Treadmill
When we are using are Nordictrack A2105 for about 5 minutes, it just stops and shuts off. The motor and the display both stop. Then it comes back on and works for about 2 minutes and the samething...
Its stopping because its drawing too much power.  most likely your belt needs lubricating on the underside.  check out your owners manual for instructions.  buy the lube from Icon fitness.  If that didn't help, then most likely your belt is already fried and will need replacement,
Mar 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Mar 01, 2009 | Nordic Track Nordictrack Apex 4100i...
NordicTrack E4000 Treadmill Logo
Top NordicTrack Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
