Question about Horizon 5.2t Motor Controller treadmill
Not getting any digital display except power ''is on'' and thetreadmill doesnt start. Mine is a horizon CT5.2. Do i need to change the internal electronic circuit?
I am unable to ''select target'' or input anything at all as except the power on display--its all blank. as soon as i start the tread mill just for 2-3 seconds ''52 minutes'' appears in the left hand side timer column and simpply goes off; thereafter there is no display on any of the panels.
    Top Expert:
  • Horizon Master
  • 12,223 Answers
1) replace the old batteries by new ones with the same MARKS
2) Clean the contacts batteries, with c. cleaner very well
3) tight the Ribbon cables from keypads from display board.,and clean it
4) Adjust the REED swtich, see the diagram, clean it, and test for open or defective. tight the connector very well and try again.
God bless you
Not getting any digital display except power ' - 1_11_2013_7_50_02_pm.gif1_11_2013_7_52_00_pm.gif
Posted on Jan 11, 2013
Static after radio turned off
You are not alone. Memory cap will be bad on front display board(C137) 0.33F/5.5v. Replacing cap will not fix, micro damaged as well. Probably can't turn off except with remote and display brightness stuck as well. Board NLA.
Aug 15, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 08, 2013 | Horizon Exercise & Fitness
How to change from km to mph
from below display board, there are small orifice. Use pencil erase point. and clich the smal switch, and ready. However some models you must go to the Menu and make the set up for to change the speed kms vs mps.
God bless you
Jun 07, 2013 | Horizon treadmill Elite T3000
How do I display a grid in the viewfinder when taking pictures?
Are you sure you saw this in your D40x?
I know this is in my camera under personal settings and called raster in viewfinder. But I can't find anything in the D40 or D40x manual.
Oct 14, 2012 | Nikon D40x Digital Camera
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
Sep 09, 2011 | Horizon Fitness Horizon T101 9 Program...
My Horizon T101 treadmill has power coming in from the power outlet but when I plug in the key it does not start. Please help. Is there a battery on the key?
no there isn't, in fact the key is a magnet plate mechanism but you should try attacking the problem by first checking the fuse which is located at the head end of the machine. If that doesn't work then remove the motor cover and get a qualified electrician/technician to check the circuit board for any possible faults.
hope this helps
Apr 07, 2011 | Horizon Fitness Horizon T101 9 Program...
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Sep 23, 2009 | Horizon Exercise & Fitness
Need help my samsung s630
my lcd isnt broken ive taken hundrerds of pics but all of the sudden it doesnt display anything just black screen like its off!! WTF!! i didnt do anything it was fine then 5 minutes later it wasnt
Nov 14, 2007 | Samsung Digimax S630 Digital Camera
Horizon 5.2t Motor Controller treadmill Logo
126 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
