Radiators seem to be very hot
Can any advise me as to weather the overheat safety thermostat should be nomally open or normally closed please.
  • 22 Answers
It could be No or NC depending on the system configuration, to determine which it is there are several things that can be done. Check the wiring diagram, check with a Ohm meter. Generally I would expect it to be N/C if it is thermal. A N/O safety would need to activate a secondary device( relay ?) generally not a good idea.
Posted on Jan 11, 2013
How to know if thermsat need change on Honda accord v6
1. If your coolant temperature is high your engine will overheat and you may have a faulty thermostat . However overheating may also be caused by other issues such as a failed water pump, blockages in the cooling system, a compression leak into the cooling system and other issues.
2. When the engine is fully cold open the hood and locate the top radiator hose running between the top of the radiator and the engine. Start the car and then feel the top hose. It should stay cool for a short time while the coolant gets to operating temperature and then the thermostat will open. When it opens the hot coolant from the engine will flow through the top hose into the radiator and you should feel the hose warm up very fast. This is an indication that the thermostat is operating normally but it is still possible that it is stuck partly open (when it should be fully open) and is impeding the flow of hot coolant from the engine. In that event it would need to be changed.
If you start the engine and you almost immediately feel hot coolant running through the top radiator hose the thermostat may not be closing at all and may be stuck fully open or partly open. It would then need to be changed. If stuck fully open the engine will run too cold some of the time and inefficiently, especially if the outside air temperature is very cold. But if a thermo is stuck fully closed or partially closed this will cause the engine to overheat and engine damage will result.
To properly test a thermostat it really needs to be removed from the engine. Please read the section in the link on Thermostats.
What to Do When Your Engine Overheats
Mar 26, 2016 | Honda Cars & Trucks
Coolant problems
Check to see if the radiator cooling fan operates when the problem occurs. If the fan doe s not operate, check for a blown fuse in the fan cooling circuit. That the engine does not overheat when idling for long periods seems to indicate the radiator cooling fan operates normally.
If the radiator fan operates normally when the engine is hot, the likely culprit is the engine thermostat, which then should be replaced. Thermostats can fail "closed," their normal position when the engine is cold. When that happens, they will not open to allow adequate coolantr flow as the engine heats up. An idling engine des not require much coolant flow to remain cool as it is not working very hard. When powering the car down the road, excessive heat is trapped in the cooling system and cannot be radiated by the radiator away due to the failed thermostat stuck in its closed position.
May 15, 2014 | Vehicle Parts & Accessories
The water in my mazda bongo wont circulate top hose gets very hot while bottom hose stays cold , heater wasnt working but now managed to get heater working after bleeding the system but bottom hose still...
Check the radiator-it may have blockage. Take it off and turn upside down and flush from the bottom.
If the top hose gets hot, that means the thermostat is opening. The bottom hose should be at least warm, and quite warm if radiator flow is good.
Feb 13, 2014 | 1995 Mazda MPV
Engine over heating
Check your thermostat, it doesn't seem to be working.
Sep 15, 2013 | Lexus RX 330 Cars & Trucks
Car engine temparature always show high,last two weeks temp is normal,some times come to high.i found water very hot in radiator,
Sounds like you need to replace thermostat. Thermostats open and close accordingly to engine temps. When reading goes hi usually indicates thermostat is sticking open, recirculating hot coolant. Now you mentioned it's been reading normal which makes me think this thermostat is not working consistent. So I'd change it now before it overheats and causes alot of damage. Regarding hot water in radiator, after running any time it's going to be hot, normal engine temp is around 195 degrees.
Feb 21, 2011 | Gaskets for Ford Laser
On my 2004 Grand Prix, my car has to be running for at least 45 minutes for some heat to work.The yellow light by the heater blinks while the blower comes on and goes off repeatedly until the light is...
It is possible that your thermostat is stuck open. Normally, the thermostat remains closed when starting cold, confining coolant to the engine block and cylinder head until it heats up. Once the coolant in the block is warm (usually within 10 minutes), the thermostat begins to open and let coolant flow into the radiator to cool it down some. A properly operating thermostat will continue to cycle until the coolant reaches the operating temperature of the thermostat--usually around 180 deg F. Then the thermostat will continue to adjust its opening to maintain that temp.
Thermostats can get stuck in both closed and open positions. When stuck closed, the engine will quickly overheat. When stuck open, the engine will take forever to warm up--especially in cold weather because the coolant is continually pushed into the radiator and cooled off before it ever has a chance to get warm. Changing the inexpensive thermostat may help correct your condition.
Jan 25, 2011 | 2004 Pontiac Grand Prix
Hello... I got problem with my honda odyssey. For the past 3 days, if i start the engine, after 5 min the temperature will goes up to HOT and engine indicator light-up. I turn-off the engine and then start...
Your English is very good.
From what you have described, which is a rapid over heating of the radiator coolant fluid and therefore a hot engine condition, it would appear that the thermostat in the engine's cooling system is faulty.
If the thermostat is sticking in the closed or nearly closed position temporarily, there will be no flow or very little coolant flow between the engine and the radiator and the engine will overheat.
You have advised that after the engine is shut off , and radiator coolant fluid has cooled, you re-start the engine and drive the car without the overheating condition occurring again and the radiator coolant temperature is normal. This time there is no overheating because the thermostat is working normally.
You should have the thermostat replaced as soon as possible because allowing the engine to overheat can cause very expensive engine damage.
If you had a continuing overheating condition then I would suspect both the thermostat and the water pump. However as the overheating seems to be only temporary, and clears itself after you have shut down the engine and re-started it 10 minutes later (without further overheating arising) then I think you only have a faulty thermostat.
Please also check that the electric fans which draw air through the radiator are operating. These run on a temperature sensor and will switch on automatically once the radiator coolant fluid reaches a certain temperature and then switch off again when the fluid temperature reduces. You will hear them running once they start up. If these fans are not working the radiator coolant can quickly overheat in various driving and temperature conditions because there will be insufficient air flow through the radiator to cool the fluid. If the temperature sensor is faulty or has died, or if the electric motors running the fans are faulty, the fans will not operate.
I hope this helps.
Dec 18, 2010 | Honda Odyssey Cars & Trucks
Ford Escape 2003. Engine suddenly overheat.
Engine over heating can be caused by a number of things. When you say the water pump and radiator appear to be ok I am also guessing that you checked the coolant level to make sure it is normal.
If the level is low then you obviously have a leak. Insufficient coolant circulating will not cool the motor properly because it won't be able to draw enough heat out. If the level is normal then you need to check the thermostat to make sure it is opening properly. To do this, run the motor to temperature and check the top and bottom hoses. They should both be hot and firrm once the thermostat opens meaning the circulation loop is operating properly. If the top is hot and firm and the bottom is cold/soft or collapsed then the thermostat isn't opening.
If the thermostat is operating properly then you ned to look for some other obstruction or cause for coolant loss. Check the head/intake gaskets, hose connections, hoses, over flow tank, radiator fins, radiator side tanks etc..
Good luck.
Jun 10, 2010 | 2003 Ford Escape
Thermo valve broken, does this cause over heating?
if you mean "thermostat" valve .. then that can fail either open or closed . if it fails open then the engine will not reach normal operating temperatures .. if it fails closed then yes the engine will overheat .. another common failure is the radiator fan .. it only runs when the car is not moving .. as long as the car is moving then cooling air is available so the fan is not needed ... so if your car does not overheat when driven but overheats when stopped or idling then suspect the radiator fan or thermal switch (mounted on the radiator) .. that switch turns on the fan when the radiator gets so hot ... you can just listen for the fan when hot .. you should hear it .. .. if your car gets too hot while driving then suspect a bad thermostat or clogged radiator .. sometimes a bad water pump (broken implellers) will cause the trouble ..
Jun 10, 2010 | 1990 Acura Legend
2004 dodge ram is over heating, the thermostat and fan clutch have been replaced.Doesn't(over heat) in cool weather,but will in mod. weather if driven over 70mph or hilly terrain due or increase of rpm,and...
Water pumps can stall out, but do you have air trapped in system.
Had you recently had the system "open" to replace hose, thermostat, temp sensor. Some Ford and GM have a bleeder screw on a high point in cooling system to bleed out trapped air.
Check your trans fluid color. Since the trans cooler is built into radiator (automatics)
IF the engine is overheating the trans CAN overheat
IF the trans is overheating the engine CAN overheat
They share the same cooling source and trans fluid gets hotter than oil, but yet it has a wimpy cooler built into radiator. Maybe add trans oil cooler to system.
Also outside temp affects the cool down rate of the radiator, ie...hot air trying to cool down hot radiator/engine is less effecting than cool air cooling hot radiator/engine
Aug 06, 2008 | Dodge Pickup Cars & Trucks
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
