Question about Graco 8A02GGG - G Collection
Took off cover to wash
Need diagram for strap configuration on bacc of seat,when i hook it up the sinch strap will not tighten or release
  • 25 Answers
You can download a PDF of the owner's manual here. It should have a diagram of the straps in it.
Posted on Feb 18, 2009
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
Dont know how to fit the seat to the bike
1. Tighten the bolt on the seat-post of your bike's seat if your seat is a bit shaky. You may need to replace this bolt if it is rusted or withered.
2. Adjust the pitch angle of your seat if it is uncomfortable. You can have it level, leaning forward or leaning backward depending upon what is more comfortable for you. Use an Allen wrench (Allen key) to loosen the bolt on the-seat post to adjust the angle.
4. Tighten the tension on the cover of the seat if the seat has one and it is loose. If it has 2 straps underneath the seat attached with a hook, release it from the hook and tighten, then re-hook the straps.
May 15, 2010 | Dynacraft 16" Boy's Wheels Bike
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Britax boulevard harness installation
Scroll down this page, someone was kind enough to take pictures.
http://www.car-seat.org/showthread.php?t=21629
Dec 08, 2008 | Baby Gear
Cant tighten straps
To answer this in detail, I need the car seat name and manufacturer. Always the best bet is to look in the original owner's manual. If you don't have this, it can be downloaded from the manufacturer's website.
Sep 29, 2008 | Evenflo Chase Comfort Touch
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Graco 8A02GGG - G Collection Logo
313 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
