Question about Crosley CR2413A Turntable
Turntable will not rotate on a brand new Cr2413a
Brand new. Won't rotate, even checked belt and turned the arm to the right.
  • Crosley Master
  • 5,126 Answers
Contact your dealer who will arrange replacement or repair free of charge.
Posted on Jan 16, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
Posted on Apr 04, 2009
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Turntable won't spin, even after switch the tonearm right
Hi, most likely the belt has come off or is stretched. Cheers John. Styluscity
Nov 22, 2012 | Crosley 0187SST Turntable
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
The 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Mar 18, 2012 | 1998 Chevrolet Cavalier
My arm won't lower onto record, the arm lowewring mechinism won't lower
After my THIRD Ion turntable had the arm-lowering problem...
I rotated the platter counterclockwise about 12 times and it worked...for now. I'll keep my fingers crossed and hope it wasn't a fluke.
Dec 29, 2011 | ION Audio iTTUSB Turntable
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Crosley CR2413A Turntable Logo
22 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
